JConcepts Thread
#6841
Yes. I really like it on my sc10 & c4. It takes alot of slop out of steering. I havnt had mine in to long,but have heard that the bearings become a little loose when they have been in for awhile. I read a post that if that becomes a problem justb drop a bit of CA around bearings then all is well. Hope this helps
#6842
I actually don't know the lengths, but 4 screws to hold the tower to the bulkhead, 2 for the alloy wing mounts, and the longest one is for the transmission case. This replaces the stock caphead screw for extra clearance from the tower.
#6843
Does the carbon fiber steering rack really help the b4.1. What will it do for it?
if i like green v1 barcodes in the rear and barcodes in the front of 2wd buggy, what would you suggest for 8th scale buggy?
#6844
PW, do have an eta for the narrow rear pivots for the c4.2?
#6845
#6846
Thanks! The JConcepts price point (what I saw on tower) has me waiting to purchase your product instead the competitor's. Keep up the good work!
#6848
PW
I just ordered the jc steering rack. You say it's best to seal the hole rack were the bearings go and the outside edges also?
#6850
Quick question... I have a set of Gold Barcodes for 1/8 that are in perfect running condition tread wise but the rims have a few cracks in them. Will doing an acetone bath damage the tire compound? or dry them out? Not worried about the foams as I have extra foams to put in.
#6851
The steering rack is the real deal! Make sure you CA the outside and inside (bearing holes). Just wet a cue tip with medium JC CA. You'll have to press the bearings into the carbon, but you'll be amazed at how much slop you just got rid of.
#6853
Sure thing....I'll grab me a fresh blade, some foam, and start knocking them out ASAP . All the new cars can wait for bodies...
#6854
Just an idea, sell the radio bags without foams to use as pit/storage bags. I use mine for tires, chargers, electronics etc. I've got about 7 so far, it's amazing how many tires they hold....maybe 18 SC tires!!!
