Like Tree387Likes
JConcepts Thread
Old 05-22-2013, 05:25 AM
  #6151
PW
PW's Avatar
Originally Posted by enron29
http://www.amainhobbies.com/product_...ion-Body-Clear
So this would be the correct body for my 8.2e, correct. How is the clearance with the batteries? I'm having an issue with my associated body when I run 2-2s batteries and all the wires there.
Yes; I would recommend you put the packs side-by-side with a slight stagger so the plugs clear.
What are the odds of you posting some pictures of that new Tekno EB48 Finnisher Body for us? They should've had pictures out by now right?
Thanks for your time.
Odds aren't very good; what would be the point of the press release... I believe they should have it finished today and posted up this afternoon
PW is offline
Old 05-22-2013, 06:56 AM
  #6152
Goosebumps short course tires... Why are they only available in super soft?
Chamelion is offline
Old 05-22-2013, 07:15 AM
  #6153
PW
PW's Avatar
Mainly because the tire was designed when 2wd Slash was the only SCT and they desperately needed Super Soft. Secondly; 98% of the time surface conditions call for a step-pin type tires, the tire performs best in the super soft compound.
PW is offline
Old 05-22-2013, 10:52 AM
  #6154
Outtacontrol58's Avatar
Trader Rating: 92 (98%+)
Can't wait to see that eb48 finnisher!
Outtacontrol58 is offline
Old 05-22-2013, 07:14 PM
  #6155
5th wheel's Avatar
Paul
I sent you a PM I could use some help thank you
jerry
5th wheel is offline
Old 05-23-2013, 08:12 AM
  #6156
tschenck's Avatar
Trader Rating: 110 (100%+)
tschenck is offline
Old 05-23-2013, 08:34 AM
  #6157
PW
PW's Avatar
tschenck...Can you edit your post for a smaller pic
PW is offline
Old 05-23-2013, 08:47 AM
  #6158
tschenck's Avatar
lol, Wanted to make sure it showed plenty of detail. Now I just have to wait for my back order on this body to ship.
tschenck is offline
Old 05-24-2013, 07:34 AM
  #6159
5th wheel's Avatar
Thanks Paul for your help and ththe e information is greatly appreciated I will give it a try what are the 3202 tire inserts 4 are they firmer than the stock in search that come with the tire I noticed on the setup sheet they're using a different insert thanks Jerry
Old 05-24-2013, 08:16 AM
  #6160
PW
PW's Avatar
When the track is smooth and med/high-bite, I like to run the Blue closed cell inserts (3206-1/rear - 3204-1/front). If the track is dusty and med/low-bite then I like the stock white inserts. I would recommend the stock inserts for now.
PW is offline
Old 05-24-2013, 06:59 PM
  #6161
5th wheel's Avatar
Ok thanks. I looked up the shocks piston part 6465. They look like what I am using now. That came with the kit b4. 1. Unless the kit ones are bad?
Old 05-26-2013, 08:02 AM
  #6162
I asked over in nitro off road thread but haven't got an answer. I'm thinking about buying some stackers in the black compound. I want to know what conditions the pro guys and normal guys like me are using the black compound in ?
evolution03 is offline
Old 05-27-2013, 06:02 PM
  #6163
PW
PW's Avatar
Sorry for the delay, but I normally don't check these boards over the weekends.
Black compound is normally used for cold weather indoor or outdoor slick groove conditions and or night time wet groove conditions.
PW is offline
Old 05-27-2013, 06:31 PM
  #6164
mxracer458's Avatar
Trader Rating: 47 (100%+)
How bad will the +3 wheels rub the stock sc10 body?
mxracer458 is offline
Old 05-27-2013, 07:40 PM
  #6165
lala4fire's Avatar
Ran them for a year with no problems
lala4fire is offline
