JConcepts Thread
#5521
Tech Prophet
the new T4 hex axles from JC allow you to NOT use the C clip setup of the AE axles. Correct? Is that the big advantage? I am asking because I already have JC front and read sc10 hexes, so if i can stay with the AE axles and run the sc10 JC hexes, I could save a few bucks for the hex conversion. Anyway, I posted this here because I plan to get the JC T4 hex rims, because they are sexy. And I need to be sure I will not be jacking up the offset with the AAE axles and the JC sc10 hexes.
#5522
Correct. It is a fresh axle design. For the T4 you would need the AE steering block #9880, JC axle #2170, and 2 of the SCT Rear Hex #2081 for front, and rear to keep the standard, legal vehicle width.
#5523
I ordered some Bro-Codes, I haven't gotten a chance to check them out yet. I was curious if they are marked so they can be mounted in the proper direction easily. I assume the lower side of the tread faces forward, correct?
#5525
Will the slash hazards work if i have the protrac kit? And this is for the 4x4.
#5527
I won't really be online until I get back...Thx
#5528
Can you eleborate? I've seen motor spray mentioned on race reports. How are people using it on offroad tires? Spray and leave on to dry?
#5531
ball cups
put some old school DU-BRO heavy duty ball ends on your car.
#5532
Tech Prophet
ok, time for the age old question. Removing tires from a rim.
I have a bad rim, tires are still in good condition though. I want to remove them and put them on some new hazards I have. I have in the past baked the tires off and soaked in acetone. I firmly believe that acetone is not great for the foams or rubber. What are your thoughts on the JC green compound tires and stock inserts? Bake or acetone? I really dont want to cut them off and reglue.
#5534
#5535
Acetone ?
Give me 1 min & a x-knife and I will
have that tire ready for a fresh insert ..
