Warpspeed Racing >
Warpspeed Racing
Warpspeed Racing
Old 06-23-2003, 09:22 PM
  #496
howard hudson's Avatar
Default Re: I am sold!
Originally posted by RCJohnny
As soon as I can stash a few bucks away (with out mamma finding out) I am buying one.
Howard...I think you need a new one, sell me yours!
Cya Friday
JOhn G.
no way it's mine I'll be there
howard hudson is offline
Old 06-23-2003, 09:29 PM
  #497
BendingCorners's Avatar
Location: Orange County TrackMasters "The Home of R/C Champions"
Howards car wasn't that fast! My car was just slow! Motor issues.
Maybe after 4th of July I will be able to purchase some motors and bring my qualifying status up a few spots but until then I will be basically powerless.
Stock Tubs are better!
BendingCorners is offline
Old 06-23-2003, 09:36 PM
  #498
always something anit it BC oh and by the way no tub lovers allowed
Old 06-24-2003, 09:30 AM
  #499
During the heats, I was never close enough to Howard to see how fast he was, but in practice his car was a bullet. It jumped out of the turns and on the strait, he pulled away from me like he had Nitrus.
DOTMAN is offline
Old 06-24-2003, 08:36 PM
  #500
StephenSobottka's Avatar
Well, the results are in..........
I beat Brian, we were very very close, and brian broke on the second to last lap, i had about 2.5 secs at that time. (dogbone popped out) We were dicing for 2nd for like 4 minutes, we both made moves on eahc other cleanly, i think we need a round 2 for sure.
StephenSobottka is offline
Old 06-24-2003, 08:38 PM
  #501
wow it didn't take long for you to post that up. so to make things fair how about we put you arm in a cast to
Old 06-24-2003, 08:47 PM
  #502
cast or none bri's car was fast
Old 06-24-2003, 08:55 PM
  #503
Axiom5B, I had a bad problem of the dogbone popping out of the front right when I was running a composite diff. You can fix this by using steel(AE) or aluminum outdrives(Niftech, IRS, TiR). I highly recommend you use IRS's pin cushions on the shafts if you use aluminum outdrives, IRS sells the shafts with them pre-installed($15-retail) or you can buy them and install them yourself. I thought of another fix for this and that is use AE's 200mm shafts but they might too long, I don't know. Hope this helps.
ZER01 is offline
Old 06-24-2003, 09:21 PM
  #504
its AX 5b that needs it lol
Old 06-25-2003, 04:01 PM
  #505
Brian McGreevy's Avatar
Thanks proudwinner, i was running the diff locked, might just have to get an IRS spool and pincushions.
Brian McGreevy is offline
Old 06-25-2003, 05:19 PM
  #506
Ax, if you're going to run a spool, I wouldn't get IRS pin-cushions. Spools eat'm like candy. Niftech makes a product called swivels that are a lot more durable. I also heard another user say he used the Schumacher blades. Both greatly reduce wear on aluminum outdrives. The swivels won't come apart though under load. For Mod, I would invest in a set swivels. They're $20 for a pair. You really only need them up front. My .02
DOTMAN is offline
Old 06-25-2003, 05:45 PM
  #507
Old 06-25-2003, 06:42 PM
  #508
Yes it was, as fast as lutz's car
Old 06-28-2003, 06:10 PM
  #509
Axiom5B, sounds to me like you still did good even with a cast on. what is trinityracinnut running a demon or something else?
HARLEY is offline
Old 06-28-2003, 07:16 PM
  #510
Im running a ft tc3
