Warpspeed Racing
#453
here is the setup that i ended up with last weekend
Front
60wt #1 piston
blue springs
middle shock mounting hole
F+2
0 deg castor block
1 deg camber
0 deg toe
bottom inner camber link
5.5mm ride height
Rear
50wt #1 piston
green spring
inner shock mounting hole
3+2
1.5 deg camber
5.5mm ride height
Front
60wt #1 piston
blue springs
F+2
0 deg castor block
1 deg camber
0 deg toe
5.5mm ride height
Rear
50wt #1 piston
green spring
3+2
1.5 deg camber
5.5mm ride height
#455
#456
Originally posted by Axiom5B
All you Cali and Florida guys are missing out on the carpet scene. Who all running the Demon will be racing at the Cleveland Indoor Champs this fall? I know i'll be there again.
But seriously if I could I would
#457
Originally posted by Trinityracinnut
AX5b- I'm testing with my reg ft tc3 tonight with foams on stock. Ill try some spec mod too. I'll let u know if I'm close and then we can have a battle of the tc3's lol.
Hey ax my money is on you bro
#460
Originally posted by howard hudson
hey Harley what surface did you run that on??
