Fuel Vaporizes
Yes 10% nitro 20% oil will not heat up as quick.
I dont know if that is the petrol u said with the high oil count, but high oil is good.
The car should not have its wheels spinning at idle on blocks, maybe a little, but not much at all.
also i'd richen slightly the top end needle, and get a slightly bigger and thicker fuel line. plus clean your carb, and clean your fuel filter if u have one.
Originally posted by V-One S
also is the fuel line going near the head? or just wen it enters the carb?
well if you haven't had a flame out you are not a rookie and know how to tune an engine.
But it would still have the potential to flame out in long mains...20-30 minutes, so I just moved it by about 5mm.
With warm up period (sometimes being around 5 minutes ) and only a 5 minute main totalling 10 minutes max, it obviously has the potential to overheat when we end up switching to longer mains (when we have a larger turn out). If you were wondering, we run triple mains when we have a low turn out.
