Novak SS13.5 B/L gearing question, for T2
jeremy I dont run the 13.5, really only ran one 2 rounds thats why I was wondering if any one had ran them side by side.
At our track we would exsperiment both ways side by side. But for some reason we dont do that any more we just race. So I was wondering if any one had. But A 40mm roll out?
That has got to be one big track I would think. I know guys are talking the same at our track but I;ve been running 4300 and dont need that much gear. It sounds to me it would be better to just bump up to a 4300?
Dont let this post be taken as a loud tone. Its not. The Most I can do with a 4300 is 32mm rollout. Medium track carpet foam.
#24
I would say that I am running on a med size track also. You can see a pic of the track here www.glennshobbycorner.com just look down the right side and click on tracks.(ya we need new carpet). As far as running them side by side no we haven't but I can say that lap times are consistantly better with more gear.
#26
That track looks similar to ours but with room for a couple more turns in the infield and a longer back straight. Just try the tall roll out at 38-40 mm.
#27
I just started running a 13.5 and am at around 36.5 for rollout right now and the power is good. Medium carpet track with foams in an RDX.....You definately need to throw gear at this motor. On the same note, I am rolling out my 4300 at 28.5 and it hangs with Komodo's all day long with the stock bonded rotor. Also using the 2007 versions of the Sphere Comp...Make sure you set the battery mode to Comp NIMH if you are not running Lipo's....
#28
Super Moderator
Originally Posted by ottoman
XMS is right... at Trackside we run 4.6 - 4.8 FDR with rubber tires. I also ran 4.8 FDR tonight at a much smaller track with no problems... motor temped at 145 (with the sintered rotor)
#29
Heres a pic of the track, well 75% of it anyway, unfortunately you cant see the last 20ft of the straight and a big sweeper. Haven't got to test yet anymore, but I will get this licked one way or the other. At least Novak will replace it for $40, so worst case I spend $40 a couple times learning to gear
#30
Super Moderator
