One Ways, Diffs, and everything in between
Hey guys. I am confused on this topic. First I hear about people using tightened diff's. What handling affects does it have? Any Negative's?
What happens if you run a one way in the front, tightened in teh back, and all sorts of these combo's you can make?
Thanks a lot
Thanks a lot
Here's my experiences, they may be different for different cars, tracks, driving styles, level of grip, etc. but here you go:
Car #1: RC Lab 7even 6.0. This is my asphalt car, it has a one-way diff in the front and a medium-tight ball diff in the back. This car gives both excellent turn-in and exit steering, but does take a certain amount of skill to drive it correctly. When done properly, I believe this is the fastest combo.
Car #2: AE FTTC3. This is my carpet racing car, it has a locked diff (also called a spool) in front and a medium-tight ball diff in back. This car has much less turn-in steering, making it more controllable and predictible than the one way (but wastes more speed) and feels exactly the same as a one way exiting the corner.
Car #3: Losi street weapon, my backup car. This car has a middle one way pulley. The one-way pulley gives slightly more turn-in, but feels exactly the same as a traditional dual-diff car on exit. This isn't the best configuration for any car I believe, because you still have some (although very minimal) slippage on the front diff unlike the spool and one-way diff on my other cars, which allow you to "shoot" out of corners because of the level of grip they provide.
Hope this helps.
Hope this helps.
Thnx that answered a lot of my question. Appreciated...
When would someone consider it time for a oneway? Would a track like socal like oneways?
SoCal is asphalt, right? If you're turning consistent laptimes and aren't hitting much, I'd give a one-way a try.
One-ways are best suited for tracks with a decent amount of grip.
The one-way pulley are good for turning in. A one-way diff are good for both going in and out of corners. A one-way pulley are a little easier to drive with, than a one-way diff.
They take some time to learn to drive with, but once learned, you'll be faster. At my opinion this is the single hop-op, with most value for money.
