1/12 servo?
Dont bother with the Airtronics 94145. Ive had two this year one used and one brand new and they both started acting very irratic ie. turns one way fine the other sometimes half somtimes full and sometimes not at all. Just may 2 cents on my experience, WILL NEVER BY AIRTRONICS AGAIN!!!!!!
Originally Posted by dr_hfuhuhurr
NOOOOO....never use Hitec servos. That one in particular has centering issues.
I think Hitec uses some sort of active centering hardware. While other quality servos are constrained to finding the same center point every single time, Hitec gives you MANY different center points. A new one EVERY time the servo moves.
This usually results you removing the servo from your car (while cursing the stupid shop owner who sold it to you) and inserting the servo into the nearest trash bin. Shortly to be followed by purchasing what you should have bought in the first place.
Hitec sucks
Hitec sucks
#20
lol jr,i had the same problems with the other ones. futaba is good to.
#21
Originally Posted by Sean B.
I have heard that before that people seem to like the 3550 vs. the 3650
Why is that?
Seems odd because the 3650 is digital while the 3550 is analog(which would not work with my HRS)
Why is that?
#22
Just to stir up the servo debate...
At the last club race a racer who used to be local came out just to say hi to old friends. Dave G. He had a diggity designs car, and he's always been fast. I took a look at the car because of the interesting design, but what caught my eye was the servo. He was using a Bluebird micro servo that you would normally find in a micro helicopter. The servo sells for $25! He qualified #2 and was leading the A main by a bunch when his battery dumped.
Not bad for a 25 dollar servo
#23
Hey Jim, Thanks for the kind words and it was good to see you again. This is what I was using. http://www.bphobbies.com/view.asp?id...93&pid=U389563
Its up to spec with everything else out there and they look really cool because they are in a silver case.
#24
Originally Posted by Racingfreak6
What is a good servo for a 1/12 scale car. I like ko-propo things but have no clue what one to get.There are so many different ones. Any opinions welcome thx
Technische Daten
Betriebsspannung 4,8 ... 6 V
Leerlaufstromaufnahme ca. 16 mA
Stromaufnahme max. ca. 890 mA
Stellmoment ca. 18 Ncm (1,8 kg/cm)
Haltekraft ca. 47 Ncm
Drehbereich ca. 2 x 45°
Stellzeit ca. 0,04 s/40°
Gewicht ca. 28 g
Abmessungen (L x B x H) ca. 33 x 15 x 27 mm
#25
that look's great , so i have order one,
now what servo saver spline do i need ??
Cheers Kevin
#27
ko 2413 ics (low profile) is something good to run.. (works awesome on my 1/10) but i have never owned a 1/12... so i dunno.. but if u like ko, certainly this is one of their best servos!
#28
BTW did you show that business card around yet?
#30
Originally Posted by mild seven
hey guys,
i'll be getting a 1/12th yokomo next week.
and im wanting to know if i can use a standard servo that ive got in my tourer, or do i have to get a smaller one?
cheers
cheers
yeah youll need a 12th scale servo cant be that expensive tho i got my futaba 9650 52.00 bucks
