Losi Taper Pins
Losi Taper Pins
I currently race at a dirt track that uses the Losi Taper Pins (pink) as the tire of choice. However, nobody seems to have them currently. Is there another tire that compares to them similarly?
I have tried the X-2000's and X-3000's by Losi, but they are not the same.
Here's a few things to try. The square fuzzies or evil twins are probably going to be your best bet.
Pro-Line Square Fuzzie #8089-02
http://www.prolineracing.com/proline.html
Pro-Line Evil Twin - Buggy Part #8197-12
Pro-Line Inside Job 2WD Rear Tire Part #8202-12
Panther Switches
http://www.pantherteam.com/index.php...roducts_id=240
Panther Cheetahs
http://www.pantherteam.com/index.php...roducts_id=205
Panther Switches
Panther Cheetahs
Panther Switch 2.0 in clay compound work very well at out track.
the panther switch not the switch 2.0 or the panther puma are both very good for a somewhat loamy track type. either clay or soft compounds, since i haven't driven on your track its hard to say exactly what compound. the losi pinks are hard to find at times, but as the cactus classic get closer they show up a but more since it is the tire of choice for that race. i am kinda surprised that it is the tire of choice at your track with a bit of loam on it they are more of a blue groove swept track tire. i think that with the loam you have the puma would be more suited. do you guys run your track wet on club nights or dry?
hey
at the track where i race at the closest thing would be a panther cheetah, which was still a little on the loose side, not enough side bite.....
We run Losi pink Tapers at the indoor track that I run at, but we started running the Proline M3 Inside Jobs and had equal success if not better at times. I'd give a set of those a shot.
would pro-line step-pins or pro-line lugnuts be a option?
but dont know if they make them for buggies
TLRacing
There has never been a single person ever to run a pink Taper pin at the Cactus.....
