Novak Super Sport Brushless Motor System
#286
by the way, has anyone used their BL setup with HRS radio system? Do you face any glitching?
#287
Am using one with HRS (3pk) was doing fine untill cap died...doing more testing today.
#288
i have had no problems with glitching using the 3pk with my brushless either
but did have a problem with glitching that was caused by the radio anntenia ( wrong spelling ) becoming loose inside the radio itself
this was caused by screwing and unscrewing it to put it away in its radio bag after race meets
#289
okie, thanks for the information...
#290
my friend car did not glitch after he change the receiver to PCM...but once he use back the HRS receiver,glitchs...
not forgetting 2 mention the rx change include a change in tx as well,but similar,both 3pk...
#291
not to mention there's a satellite dish just behind the driver's stand... would there be a cause as well???
#292
can i keep up with an nitrors4ss with this?
#293
What kind of temp are you guys finding at end of race with your Novak Brushless motor and speedo in touring cars?
Temps for myself are 240 F on Speedo and 180 F on motor, wondering if this is a little excissive heat wise with car is XXX-S.
#295
Hmmm 240F? that seems a tad hot for the esc. Mine was coming off after 8-9 minutes and the ESC measured ard 180-185F and i still felt it was a little too hot for my liking, motor was warm to the touch. Ambient temp 30+-C.
Jeff
Jeff
#296
is there a new brushless comming out by novak
if so can i use the original speed control to run it?
#297
seems like there's a new esc with motor for monstor trucks out soon and also a new motor ss4300 which is close to stock spec out soon.
#298
I've been lucky enough to have been testing one for the past 6 weeks or so running locally in normal ProStock class.
The best NEWS is that you do not have to work on the motor all day/nite whatever. Just work on your car to tune it to run good, take the extra $$ and invest in Tires, Inserts, etc.... and go even faster
#299
just wondering but ..... (kinda off topic)
do any of you run a 414mII... and have to put an extra belt tensioner on the top?
do you even put it on the bottom?
#300
