Novak Super Sport Brushless Motor System
#271
B4 Overheating
Hi, Haven't got any respond from the last post, so I'll try to explain it again further.
I got the BL recently and is loving it. It has more power than I can handle.... for now . I've installed it on XXX-S and ran great without any problem, the final ratio is ~7.5.
My B4 is a different story. Firstable, I can't find a spot to mount the esc except on top of the battery, otherwise the ESC will touch the body. Secondly, the over-heating is becoming a problem. I'm running at the recommended ~9 ratio, but it still overheats atleast twice on a pack of battery. Any comments are welcome.
HELP!
HELP!
#272
I think you're way over geared. I'm running an 11.61. Granted, that's on a short track in a XXXT, not a buggie, but I think you probably need to be in the mid ten range at least. Gear it back a little and try it. As far as the mounting, the only thing I can think of is cutting a hole in the body. Maybe this will also help in cooling the heat sink allowing more air to flow across it. I wouldn't want my ESC exposed but I also wouldn't want it sitting on top of the battery. Kind of defeats the entire low CG design of a B4.
#273
#274
Anybody have any information about the new SS4300 "stock" version? Other than what's available at:
http://www.teamnovak.com/products/MOTOR/ss4300.htm
Novak's site says "soon." Any idea how soon is soon? Are they talking about October? 2003?
I race stock and am considering buying a better ESC and a lathe. If I can buy the brushless SS4300 (and my track lets me use it) then I'll end up much better off.
Anybody know anything that they can share?
#276
but check with your track first - the super sport model was too fast to run against stock even in the limited mode. this one you do not have to run in the limited mode -
#277
I also have been looking at the novak stock motor. Have you noticed any change in the way you gear the motor?? I was thinking with the lower wattage motor that you would be able to gear lower and still not over heat the speedcontroller. Please let me know.... Thanks!!!
#278
Its like having a nearly perfect stock motor run after run
#279
any1 experienced any glitching problems with the BL?...
if i'm not wrong,the novak ss5800 has fail-safe rite?after i switch my radio from my 3pk to KO ex1-mars,the fail-safe doesn't seems to work...
also,my friend is experiencing glitching with his 3pk on HRS,mine's on PCM...help pls...
#280
also,they experience a problem whereby the car will throotle,then brake,throttle,then brake...seems veri odd...
my friend's car even went into reverse when we were on program 2 without reverse...
#281
Hi ijnek, i also experience the jerky motion on my brushless sometime back. It seems my capacitor was dead already...i have yet to change my capacitor, but i guess its worth trying. Hope that helps.
#282
dead capacitor? I'm with ijnek and i just bought the BL...
tat testing was the virgin run... hmmmm...
another question though,
would a satellite dish in the precint cause any glitching problems???
#283
hey guys - i would suggest you contact Novak via email or call them for support/suggestions especially if these are new. I've not had the experience your mentioning.
been racing one since early this year without issues in both a losi xxxs-g, EVOIII and barracuda R2
Contact Novak best bet
#284
okay, thanks for advising.
I had just emailed them and now awaiting a reply...
#285
Got an email back from novak, still need to test out their recommendations...
