Alex Racing Barracuda R2 & R3
#1351
carbon shaft to aluminum
I want to change the center shaft from carbon to aluminum. Is there a hopup aluminum shaft from alex racing or I have to get Speedway pal system or Square aluminum motor mount and drive assembly?? I don't want to spend a lot so any suggestions ?/
BTW im running stock only.
#1352
Re: carbon shaft to aluminum
-Dave
#1354
Thanks for the help guys. I'll try running it with a carbon shaft. And on the rear hub, Can I buy a different hub to lessen the toe in or I have to buy the gold ball studs ??
#1355
-Dave
#1356
I tried flipping it but it seems like its toe out. Im looking to get 2 deg toe in.
#1358
Randman, The aftermarket pivot balls are concentric so you adjust untill you get the toe in your looking for.
#1359
Does anybody have the link to the English version of the Square website? Thanks
#1362
the pivot balls have a notch on each one that you point in different directions like 10 and 2 on top and 7 and 5 in clock terms
#1363
#1364
R/C Tech Elite Member
