Alex Racing Barracuda R2 & R3
#9316
It's post man pats van I tell you he's gone stealth with the black
#9317
Regional Moderator
Originally posted by ImGoinRCn
EA, does this answer your question?? R/C delivery vehicle
There you go heath man thanks for the jerky again bro
#9318
Originally posted by Ko Racer
Its not going to be a Hara body is it
MAZDA 6
HPI AERO STRATUS
#9319
Regional Moderator
Very nice ramon I ran one of those new hpi bodies last night a couple of times and seemed to handle well
Got it for 20 bucks painted that is the only reason I bought something that was hpi
#9321
here's the shell I ran today, it got a few looks, something different from the usual white front with flames etc...
not bad for a spray can job, you can't quite see the blue/silver marble effect, almost looks like water.
#9322
Regional Moderator
Looooking good there herm
#9324
just to let all the peeps in the UK know that the 'Cuda has now got a UK distributor along with OVA chassis. www.planet-rc.com
#9326
R/C Tech Elite Member
Originally posted by AWOLsoldier
Here's what I was talking about. See that gap between the top deck and front bulkhead? The end with the alum. shaft holder doesn't do this.
#9327
awol.. is that the R2.. here's my wild guess.. i didnt read the entire last few pages of the post.
if your not gonna run the gear case.. then you need to buy the short steering posts... if not.. you'll have that gap. so you either shim everything to match the height of the steering posts.. or dont shim, but buy the shorter steering posts.
#9329
I say it's the plastic holders.
#9330
AWOLSoldier,
Even if you use the plastic shaft holder that shouldn't happen...unless the plastic shaft holder is tweaked, or the upper deck is bent to began with. Try switching the alloy shaft holder to the front and see what happens. You can try the other plastic shaft holder and see if it does the same thing.
Also, you might want to also check to see if your upper deck is flat to began with. Lastly, if you're using different screws than what came with the kit, you might want to also check if the screws for the upper link that's on the underside of the upper deck sits perfectly flat in the countersunk (and not sticking out) because that can catch the bulkhead and raise it like it is doing in your picture.
Steve Wang
Steve Wang
