Alex Racing Barracuda R2 & R3
#8806
Originally posted by Randman
aaah, you got a pink one... right on!
But just remember who the first guy to bring the pink barracuda to SoCal was
but grasshoppa will be first to bring new color R3 to SoCal thanks to sensei!
hahaha i crack myself up
#8807
Originally posted by Herminator
You could fit a 73 spur gear but I wouldn't advise it, you're likely to have someting come through the bottom of the chassis and scrape the spur, outdoors I'd probably try and stick to a 69 or 70 tooth spur, especially if you've got rideable curbs.
#8808
Originally posted by Hebiki
yikes. i better remove that 76 spur then. it fits.. and it BAAARELY touches.
I'm suprised it's not turned into the nice smooth disc by now
#8811
Originally posted by rc-zombies
put a piece of protective tape under the chassis where the spur gear is and you don't have to worry about dirt and pebbles getting in...
#8813
how about placing a thin sheet of plastic over the opening of the chassis and tape around the outer edge?
#8814
I cover the whole bottom chassis except the motor hole.
Not sure if it's a good idea.
#8816
I use Loctite glue remover. Apply, set it down for a minute, then it become gooey. WD40 or Goo Gone afterwards.
#8817
try again John S silly PM inbox with a limit of 500
#8819
Originally posted by johnny55
annybody know a website where I can get gear ratios for R2? Thanks.
#8820
All the instruction manuals of the R2 or R3 are in Japanese? No English?
