Alex Racing Barracuda R2 & R3
#8176
Originally posted by Randman
So are you going to make the 2 day race? Jason Erthracter and I are propably gonna carpool up there and get a hotel, just want to know if there will be anyone else I know racing.
#8180
R/C Tech Elite Member
Originally posted by rc-zombies
I doubt if the wife will let me get away for 2 days of racing. Might be able to go watch the mains and help you guys out...
#8182
Jason has a hot setup for the track, so we'll be set there. I just gotta decide what class I'm gonna run, stock and 19t run rubber, whereas mod runs foam... I've never run carpet with rubber before, but wouldn't it be slicker than asphault?
#8184
Regional Moderator
Actually..no... lot of traction with rubber tires. Sorex 23 or 27's work very well. especially with the TQ Orange traction compound.
#8185
Originally posted by ImGoinRCn
I thought you all was running foams on carpet...I used take of 27s and they were just fine. I don't like soft tires, it takes away speed for me and I need all the help I can get. I like rubber tires on carpet better than foams.
#8187
I'm just the opposite, I actually run softer tires than most, helps me dive the car into the corners while racing, I wish that the stock or 19t class ran foams, my mind would already be made up if that was the case...
#8188
Regional Moderator
#8189
Originally posted by MikeR
Did you use to run sedan at that old slot track in el cajon? The trick there was to use mixed tires- sorex 28 in front and sorex 20 in back. This prevented traction rolling in the corners and gave extra stability on and off power. It wasn't the best conditions for sedan Another carpet track I went to worked great with same compounds (softs) and another track was so bad you could only get one good run out of rubber tires before you had to put on a new set otherwise the car was crap. It's all relative, but you're right- foams would be better
