Alex Racing Barracuda R2 & R3
#2612
Originally posted by Herminator
1350grams total? you including a shell in that?
if you are then where the heck is half your car? still in the box?
the cuda is light but not that light
Oh, and no battery mount or plate since they didn't fit.
Dan
#2613
Re: Re: Re: Re: First Test drive
Originally posted by rc-zombies
If I ever get down there...I'll definately bring mine..
and we can have an Orange Tripple Threat.
DAn
#2614
Originally posted by Maj. Teeth
Ok, maybe add 30~50 grams for the lid. But yes, I'm running a KO PDS 2143, KO RF301, LRP Comp ESC w/CAP and did without the Orange bodypost. The car is super light. Could be because of those titanium torx screws.
Dan
Dan
still seems awfully light
#2615
Dan
Dan
in the front where it's at 90deg. I cut that off... on the rear..
I pretty much took away half if it off...only the outside battery support is there.
#2616
What cells are you using on there?
I'm running Fukuyama Racing Cells, they're GP3300. The KO Receiver and Quantum Comp ESC is super light to begin with.
Dan
#2617
I just cut off the inner section to make mine fit.
Dan
#2618
I hadn't thought of that. I might give it a try but from last night's run, strap taping them is great! the cells are neatly secured. The car is perfectly balance at this point but I don't know if that'll be the case with the bulky brace and orange alum top plate. I'll give it a try today and see if it'll throw off the balance. I've got some really light electronics on the other side.
Dan
Dan
#2619
I'm using a KO 297 reciever so no real difference there, my ESC will be heavier but it's no monster, probably around 15grams more. Still 100g difference, you using the alloy battery strap? I have replaced half my screws with titanium ones. You filled your tyres with helium?
#2621
Originally posted by ImGoinRCn
I have never weighed my Cuda...I'm afraid it doesn't weigh enough....oh well, when they get back to weight rules, I'll worry about it then. BTW, where's Dave and DJ been hiding?
#2622
Regional Moderator
it's very likely to be underweight, with a can painted shell (thickish paint) 3300GP's and alloy battery strap my car is on the 1500gram limit.
#2623
Dan
Dan
My liteweight NSX is 88g
#2624
Dan
#2625
Originally posted by RedBullFiXX
fyi...if you go light on the paint TC bodies weigh around 100g Maj.
Maj I'm using a pair of alloy posts to mount my battery strap on, it's fire as long as you mount the spur to the rear of the car. Looks very nice too
