CEN Matrix TR
#1444
I ended up getting a new cen bell cen gold springs and King heads mugen shoes. I hope they engage really snappy. See the reasoning for all the clutch questions is I have never ran aluminum shoes before I always used carbon. But I noticed that what I was using wasnt hooking up properly because my clutch bell would get burned, all the way around it would be purple. And I would dremel it off outside and inside weekly, and my carbon shoes dont even look used at all almost a gallon later. I do know that the coloration on the bell is from slippage and I dont want that no more. The TR is the only truck that ever happened to me with so I just attributed it to the weight of it. But now that I fell in love with racing it I went ahead and spent the $ and went to aluminum. What do I do for prepping the new bell and shoes before installing them? Robert I checked KMW but they are shut down right now, dont they sell different susp blocks and shock towers and a few other things for the TR?
#1447
Hey guys.
Just wanted to say thanks for the insight on Matrix TR, helped out a lot. Got my truck working pretty well. Still not 100% happy with the shocks, but just installed the reservoirs and different springs. I’m just running around my house and might go race shortly. Haven’t driven in 10 years, these 1/8 trucks are super fun, built a rhythm section @ my house.
Great truck, good times...
Andrew, I installed those 17MM hubs. Any better shims?? I used ofna 8mm and I would like to see a shim with a larger OD??? Feelings?
Thx,
SIXPAC
Sorry on the photo size, new to this...
Thx,
SIXPAC
#1449
it seems like I'm getting blowbye past the piston. I'm running losi 80W with #1 pistons,
with red kysho springs. when I drop test it smacks the ground (waist height) I'm sure it will be fine for the tracks, its just when I hit my 20' triple it smacks the take off pretty good. I just don't want to wear threw the diff releif. I was thinking jammin or kysho shocks if the res don't help. I just think if CEN made some works machined shocks our trucks would be deadly!
any progressive springs?
how much are the mugen shocks and do they have machined pistons?
#1450
Sixpac, try using two of the small washer on each side of the pistons instead of one. We were having problems with the washer slightly getting bent and then the piston would tilt sideways and the suspension would do exactly what you are talking about. With the two washers on top and bottom of the pistons problem solved. We run #1 piston in the front with Losi 60wt and #2 with Cen 30wt in the rear on the stock TR.
#1451
Hey thanks, Ill give that a try. I want to run all CEN parts and don’t want to spend the money on new shocks. It just seems that plastic pistons are not ideal materials to be used. I would like to see a brass piston with a wear band (or something similar) you could do so much more with shocks and these trucks need it IMO.
With that set up do you guys have big jumps ETC??? The local track revelation has some big $hit... Not calling you guys out, just want my truck to work. I know these trucks are built to smack the earth; I just want to control it better!
Post up some photos and videos of your trucks. Sounds like you guys are the team to beat out of FL. You come out to CA much??
Any feelings on the wheel shims??
Robert, how is the Havasu track??? I grew up on the lake and river and still go out a bunch. To small for a 1/8? You know Shawn doggy out there???
Thanks post up some photos and flicks ALL.
#1453
Can you post a link or part number for the washer. My issues is when I come off a jump the back of the truck bounces up. I have the red Mugen springs with stock Cen Shocks and Stock RTR Oil in the back of my Cen Matrix TR.
#1454
I havent had any problems since ive figure out my set up which is #2 all around 60wt fr and 35wt rear AE oils and I beat my truck up pretty good. You need to change the oil frequently, I do about every 2-3 quarts. I love the stock shocks, I bought everything to rebuild them but never had to yet. These are the most durable shocks "internals wise" I have ever seen. I am happy with the stock springs but I do wish Cen would make at least options for us.
