CEN Matrix TR
#1186
Hey can anyone give me the part number for the XTM backplate that bolts on to the Cen 28 with no mods? Thanks
http://www.amainhobbies.com/product_...oducts_id/4331
#1187
Guys,
This is the engine mount that fits right on the CEN Buggy and Truggy from KHZ ? :
http://www.amainhobbies.com/product_...oducts_id/7579
If using this one, engine mount plates are needed or this thing replace the whole setup ?
thanks,
thanks,
This replaces the whole setup.. comes with 1 set of uppers... get a spare set of uppers and you can swap motors 5 mins before any Main.. its awesome..
#1188
got any pics w/ the st-rr tank ?
#1189
this is the one i have used in the past and it works well on the SH28
#1190
I am putting some of the final touches on my TR..it's starting to warm up here finally and I am getting anxious!! LOL Anyway, I have a clutch out of a Savage, the flywheel measures 33mm accross, could anybody tell me what the factory flywheel measures, I wonder if this one will fit, I am using a starterbox, any help is appreciated!
#1192
I have done two of these now and only one required any work on the backplate so hopefully you'll get lucky!
#1193
#1194
Ok, one more question about starting. Im really back and forth right now between starter box and roto start... I know the pros and cons of each. Can anyone confirm that the rotostart backplate for the XTM 24.7 will fit the TRs
.28 engine? Some others in a different forum said it worked fine, but I dont quite trust it until I hear it from one of you....Thanks
#1195
Well ... finally got time to test my CEN Matrix TR Truggy and break inn my GO TECH .25 6 ports Engine (stock).
Great engine so easy to break inn ... after 4 tanks i was leaning just a little bit in order to at least make up some speed to test the Truggy, the truck its awesome, at start i felt it a bit on the heavy side but the performance on the track was very good even on a very rich engine. We had couple of other trucks at the track practicing and comparing the performance it was great (v/s losis, mugens, hypers and HPI's SS's) so im waiting for the next weekend to get into my first race with the truck. Track its grass based and small/technical so i used a 13T clutch bell instead of the stock 14T, on race day i will decide if it was a good choice or i need the 14T one back.
Engine was very good and easy from the beginning and after 750cc's of gas (aprox. 5 tanks) it was starting to rev up very good and even on rich side. I ended puting 1 liter of fuel through the engine (aprox. 7 tanks) and i think i will put another 3 on this rich setting and will start to close needles. Temps during break inn went on the 190F to 230°F range ... the only thing that always concern me its the heavy grass track where i usually race and practice in Colombia that always leaves to hot engines, hope i can manage that on the GO Engine. Used 3 shoe alum 7075 shoes with 1.1 springs from VP PRO, very good feeling.
Ohhh BTW, the FEMCA 0801 (under new EFRA rules for 2008) from GO TECH its awesome ... very good feeling in bottom but superb performance on medium to top range of RPM's.
Well, here you have couple pics ... cya !! :
cya !!
cya !!
#1196
TR looks great Pato. Good luck in 08 with the Cen’s. My son Justin Love’s his TR. We will be watching on live RC cheering all you on at the Worlds.
Any chance you’re going to make the Buggy or Truck Nationals in the US this year? I won’t be at either of these races but Justin will.
Let us know how the fuel efficiency is on the .25, Again, good luck.
#1199
1. cord breaks
2. one way bearing fails
3. power reduced by backplate
Rotostart's only improve reason 1. Reasons 2 and 3 will still be a problem.
Get the Sportwerks backplate with the Mugen starter box below and you'll be sorted.
http://www.amainhobbies.com/product_...oducts_id/1743
#1200
1. Do you run your truggy with this amount of toe out (from the pics it looks less than I use)
2. it looks like you are using the stock front hub carriers and rear hubs not the CNC ones. Any reason?
3. the fuel line looks like it is travelling at a bit of an upwards angle from the filter round the cooling head. Have you ever tried a shorter route direct from the filter to the carb?
4. it looks like you are running proline LPR crimefighters. do you use these on grass?
Thanks for your time.
