CEN Matrix TR
#589
Maybe I am just lucky, but I have not had my front bones pop out with this setup. This is how my shocks are mounted. I use the short ends on the front.
top: bottom-outside
bottom: innner
top: bottom-outside
bottom: innner
#590
yes they pop out when the shock is at full compression, at least thats when mine have done it anyway, because it locks it in that position, as long as you dont try to move after it jams, you can twist it back in, but you still loose a lot of time doing that,
from what i've heard if you have the shocks mounted on the insdie hole of the arm they dont pop out as easily, but that is basically because the uptravel is being limited in the same way, the shock will bottom out sooner, also if you have a front sway bar it doens't pop out as easy because the bar limits travel a little too,
and trust me nothing in my front end is set up wrong, other than I like running the shocks in the middle on the arms and dont like a sway bar in the front, I've been in this hobby for a long long time, and I know how to build a car properly,
for the buggy if you drop to the lower set of holes on the tower, it should fix it, I've got about 1/4" of fuel tube on the buggy, but I'm also runing the KMW short shocks, so I get more uptravel than the stock set up anyway,
#591
top: bottom-outside
bottom: innner
front and rear Short rod ends is what I use.
bottom: innner
#592
lockmouth-ill post a clear pic of the front of my truck as soon as i get home that way you can see the hole mounting and everything cause i have had a hard landing before and still did not have a bone pop out
triplex-jt-im running short shock ends in the front and long shock ends in the rear
#594
so basically all youve done is fortify what I already said, if youve got the shocks in the inside hole on the arms, the lower set of holes on the tower, and a front bar, the up-travel is limted enough that they dont pop out, which is fine if you like the way it works set up like that, but that set up isn't going to suit everyones track or driving style
#595
ive ran my truck with out the sway bar and still no poping out and you guys ask me what set up i had since my bones wernt popping out and i told you I NEVER said use my setup if youlike the shaft popping out losing your 1st place positon setup then run i dont care i was just answering a question
if you dont try different setups you will never know in the first place what you did
#596
wow easy, why did you get all offended? all I said was you fortified the point?
its not so much the bar that limits the travel, it does limit it, but not a huge amount, the big thing is mounting the shocks in the inside hole on the arm, and lower set of holes on the tower,
another big factor is the track too thgouh, the track I race on mostly has a set of double doubles that are going away from the drviers stand, so its hard to judge them, and if you dont hit them right you pound into the top of the third jump, thats where my bones jammed, and I think thats where my dads jammed too, although I wasn't watching when his did thgouh,
#597
We are having a CEN Summer Sale for the month of June - $50 off all CEN Kits and Parts orders of $200 or more.
Call or e-mail to order.
http://www.machinesrchobbies.com
#598
well since im not on here to fight back with time wasters like your self i will not reply your post but lets make one thing clear i posted some advice for people that were having trouble whether you, them, your mom, or hell your grandma wants to take it and use it for the benifit is not my desicion i did my part
and since you brought up blaming it on the tracks jumps (double to the third one) i cant even force my shaft out by hand enless i break something i have the same shock set up in the front andy runs and its nice smooth and preforms great
#599
Robert please dont take this the wrong way as I know you are trying to help .. but sometimes you statements come off somewhat ABRASSIVE!!.. not that Ive ever been offended but I can see where someone might think it wasnt ment to help... Ive actually had to read some posts twice to make sure..!!!>.
Its okay.. We are all friends..Now lets get back to racin.!!!!
#600
