CEN Matrix TR
#257
The TR Arena does not need many mods - it is great right out of the box. But remember to grind the front arms slightly where the caster blocks touch to allow for max down travel and the front knuckles for max steering throw. Once you have a ton of down travel and tons of steering, it is near perfect and hard to beat.
#258
One other mod we have been doing. Put a rear inner arm hinge pin in the front upper tie rod to keep it from bending during hard crashes. It fits perfect, just tap it in with a small hammer. They are hollow, so they can bend. Hopefully CEN will have solid one soon.
For the rear upper tie rod, you can use the alum one to save weight - it does not bend when in the rear.
#259
When building my shocks I have the option to use the long or the short rod end. The instructions tell you to use the short, but the RTR comes with the long on the rear shocks.
Which ones are you all running?
#261
CEN MATRIX TR TURNBUCKLE MOD
If you are like me you may have bent a turnbuckle or two on your Cen Matrix TR
This is a mod that must be done in my opinion, if you are thinking about raceing.
With this mod you no longer need the upper arm mount on the front. Also this will give you a more bind free suspension
I've put alot of time on my Matrix TR an this is one nice truggy.
Here is the fix to this problem, I used the following part #'s
XRAY
#352150
#353170
LUNSFORD
#LUN1580
#LUN1589
This complete fix cost $75.00 @ http://www.stormerhobbies.com/
XRAY
#352150
#353170
LUNSFORD
#LUN1580
#LUN1589
#262
We are running box stock setup other than Genes cross pins. This truck turns on a dime and is super stable. Enjoy your new TRuggy
#263
Thanks for the shock info.
My truck is built, the only thing I need right now is a motor. I brought it to our local carpet track today to show it off to everyone.(outdoor has not started yet) I think it went over very well with the club racers.
I did have a few things left over from the kit. I had three metal posts and some kind of a servo mount left. These must be in parts bags from another vehicle...possibly the buggy??? Let me know if I missed something.
Thanks again for all of the helpful info.
#264
XRAY
#352150
#353130
#353170
LUNSFORD
#LUN1580
#LUN1585
XRAY
#352150
#353130
#353170
LUNSFORD
#LUN1580
#LUN1585
#265
Originally Posted by t4usee
It does'nt look like you can make all the adjustments in the rear tower now? I may be wrong though. I wonder how hard it would be to have a machinist cut some turnbuckles? Or fill the hollow part with a herdened pin. Anyway as usual, I am impressed with your mods. to the truck.
I'll take pictures again after I get everthing together an put it on the Hudy Board before the Alabama Indoor Race ( AIC 5.0 )
Just to let you guy know I even put Lunsford titanium turnbuckles on the steering rods and servo arm. If I change them I might as well do them all I'm going to weigh my TR when I'm all done.
I'm loving this truggy
#266
XRAY
#352150
#353170
LUNSFORD
#LUN1580
#LUN1589
XRAY
#352150
#353170
LUNSFORD
#LUN1580
#LUN1589
You will need to run short end on both sides in the front to get 100% adjustments both ways.
So here is the updated part list with quanities
XRAY
#352150 x 4
#353170 x 2
LUNSFORD
#LUN1580 x 2
#LUN1589 x 2
The front suspension is super smooth an free with this mod
#267
2nd place This weekend and only my second time out with the truck...
For anyone who has any hate for this truck... you are just in doubt.
Turns on a dime, and really smooth... Lovin it !!!!!
Lovin all the help you guys give too...
""" Question for Gene the Machine.."" If i like the way the truck runs now.. running grease on the lsd in the rear.. would I be able to keep the center LSd and run crosspins in the rear and still have a noticeable difference...???
#268
I did have a few things left over from the kit. I had three metal posts and some kind of a servo mount left. These must be in parts bags from another vehicle...possibly the buggy??? Let me know if I missed something..
also you can use the rear inner hinge pin inside the front turnbuckle, according to Gene it fits right in, and you wont have bending issues anymore,
I like your link mod, just for the fact it would be alot easier to adjust camber, I hate using the hole things in the stock links,
#269
Thanks I figured they were for the buggy
#270
Part MX074 - $7.99 is all you need to do to stop the front upper tie rod from bending.
The mod of removing the front upper arm I have tried. It allows way more flex in the front susp (arm, caster block, upper arm, front shock shafts, ect), so it will completely change the handling of the truck (steering response, bumps, ect). It is not a bad thing, just different. It may be better on bumpy tracks.
