EVO WCE vs EVO Standard
#31
Originally Posted by racenut123
is 439.99 a good price for an evo WCE RRR?
#33
Engtat
#35
Originally Posted by tony montana
So the v1rrr evo wce is the latest car correct? What is the difference in the regular wce and the evo wce?
Correct....
Differences.....shocks, shock shafts, springs, main shaft assembly including pulley, brake pads and rotor......rear bulk heads, upper deck with top mount servo...also has neat little holes in upper deck near ackerman..this allows you to align ackerman perfectly, hollow middle shaft..very light...., light weight flywheel, nice blade type sway for the rear,
hope I didn't miss anything.....if I did please post
Robert
#37
Originally Posted by rpoage
Kyosho currently sells the following versions:
KYO 31256B V-ONE RRR 4WD PureTen GP
KYO 31258B V-ONE RRR WC-Edi 4WD GP
KYO 31259B V-ONE RRR EVO 4WD GP
KYO 31260B V-ONE RRR EVO WC-Kit
This gets a little confussing.
this is the one you want
#39
hmm
Originally Posted by Scott Fisher
I found one today. Should have it sometime next week...
#41
sirio
Originally Posted by MCRUZ
Try our Sirio engines and pipes. Excellent combination when used together!!
#42
EVO RRR Motor
I am new to Nito.... Just getting back into the hobby after a 8 year break. Back in the day.. 1/10th electric.. Back in the Spider days... and TC3.. anyway. I found a kit online for 340.00 and now i need a motor pipe and servo's. I have 10 miniz's and 2 m18's so i have spectum and a Helios.
What motor and pipe are a good combo? I think i can handle the speed and i understand I might want to invest in 2 motors.. just in case.. Everyone has the V - one RRR here.. I only know a couple of them. I want to get my car built and ready to go soon..
Any suggestions would be appreciated..
#43
Originally Posted by Artificial-I
So the EVO is the better car? Or does it perhaps got somethings and the standard wce has its own?
This is the kit you would want.....
#44
Sirio Evo 3 with Sirio 2611 header/pipe combo or Nova Rossi 12+3 ct and Nova Rossi 2630 with 5 conical header from Nova rossi...any one of these combos will work well hope this helps.....oh...servos highly recommend the Futaba 9451 for steering and throttle.....
