Yokomo MR-4TC SD
yes, you can buy the castor blocks seperately. Check on www.speedtechrc.com they should have them there along with any other parts you need
Originally Posted by olhipster1
I'm having trouble with the steering cranks.
They either keep getting loose during a race or I have to overtighten to keep it from happening which in turn makes the steering to slow. Is there solution or fix for this?
Originally Posted by Matt Howard
Where did you purchase it though? I'm going to check to today but I'm pretty sure Yokomo USA only brought in the conversion kits and not the full kits.
very pricey in england for us tho.
Hi,
I destroyed my good old servo in my foam CGM last weekend and now I'm looking for a new one. The servo of my LCG will switch over to the CGM and the LCG will get something new. Which one would you recommend?
I'm thinking about the KO 2343 and the KO 2363. Where is the main difference? Just the possibility to setup the servo and the cooling plate?
I'm not sure about the FET of the 2343.
Cheers
Chris
Cheers
Chris
Originally Posted by speedy-932
Hi,
Cheers
Chris
Cheers
Chris
Originally Posted by agower
i think yokomo usanormaly change the kits slightly and instructions which is why the delay, i know you can get it from www.precisionrc.com in japan and www.microtechracing.com in england.
Hi,
Cheers
Chris
Cheers
Chris
"RaySpeed Piston"
A racer gave me his spare rayspeed White pistions with 2 holes in it, are them the 1.0mm or the 1.1mm? I knew there is the black type with 2 holes in it as well. Which is which?
Thanks.
Thanks.
Originally Posted by MARKANO
"RaySpeed Piston"
Thanks.
Thanks.
YOK part for FT TC4
BD-118T Battery Tray. Is this the Yok part # for the white rubber looking things that the batteries are laying on the YOK BD.
I know this is the SD forum but I'm just looking for someone how knows about Yokomo & AE parts.
Do you think they would fit on a FT TC4?
Regards,
E
Regards,
E
no they wont becuase how they attach to the chassis the cutouts are completley rectangular so they fit it, also there is extra space for them, ie if they werent in the car then the battery bar wouldnt be tight and the cells would just fall out.
so simply no they wont work in any other car apart from the yokomo bd and lcg.
Part #BD-118T is the correct part number for the battery tray, also they are black not white, that picture is a pre-production car so they look white but they are really black. And I dont think they will work on the TC4 without getting your file out.
You could always sell your TC4 and buy a BD
Hi,
does anyone know where I can get the Rayspeed spring retainers?
Shops all over the world are welcome.
We have a new carpet track here in Munich. It's nice to drive, medium grip and lots of corners. I will post pics later. The LCG was dialed and I lowered the current track record to 12.5 secs... unfortunately it was just stopped by hand... But with 17T it was 12.7 secs which is fast enough aswell...
Cheers
Chris
Cheers
Chris
