Yokomo MR-4TC SD
Any word about the new SDW upgrade conversion for the SD?????
I heard right behind the BD so I just thought Maybe someone might have heard something....HINT HINT Matt or Steve...????
Also if I can not wield the new BD as well as my SD I might just convert the SD to the SDW and run the BD for the Mod and 19T classes. Right now I wield the SD pretty well in Stock. SO I will have to at least try the conversion.
Thanks,
Stephen <><
Thanks,
Stephen <><
have you guys seen this, any thoughts
http://www.yokomousa.com/newproducts...-644ts_450.jpg
one way shaft.
one way shaft.
It looks like the first ever one way shaft ever. Guess they do have their own ideas. I bet I will have one in my SD when it comes out. That would definantly help my steering...Sheesh I bet Tamiya and HPI are going to rush to get one out ASAP...
Stephen <><
while it probably will have a little "slider" action, it actually is a shaft one way.
Stephen <><
Originally posted by Mr. Shookie
And they say Yokomo doesn't come up with their own Ideas...
Stephen <><
Stephen <><
cant remember exactly but i think its irragang? / friend of mine ran one at the 04 nats...
What benefits could be reaped from a one-way shaft? I've seen the one made for the TC3, but then, I never picked one up because I did not know what it would do for a car. Please, any one who has used one please post up.
-deceleration of front universals / drivetrain and drag issue; with the rear diff/universals. rear diff/drivetrain has less drag and the front decelerate seperatly from the drivetrain and univerals.
do the math! (my new saying), b-main = motocross start!!!
Got it!!!
And I'll Do the Math!!!
i thought the oneway shafts that are already out were actualy oneway front input shafts? but actually the main shafts?
a gower
a gower
a gower
a gower
sorry i wrote that wrong, i ment i no the yoke one is a centre shaft but i thought that the ones already out frm differnent makes were actualy inout shafts and not main shafts.!!!!
I think the main idea is to combine the front spool with this center oneway to have better cornering speed.
Doesnt that defeat the purpose? I thought the main point of the spool was the ability to break.
