Yokomo MR-4TC SD
yo
i have a yokomo sd ssg, it is durable, im a ok driver my skills are increasing, even wothout driving, but i smacked into a few things, only thing that broke onit was the rime, all the spokes broke right off the circular part of the rim. itw as pretty funny. I like it a lot.
question
i had my steering setup up a different way than the stock location. it was parallel to the front drive shafts, i'm gonna switch it back to the stoxk way though, but was wondering, is it gonna make a big difference, for a beginning carpet driver.
92tsi,
Is this on the CGM?
Blakesrc,
The upper sway bar does not come with the SDW it was from the old belt drive TC i believe.
Is this on the CGM?
Blakesrc,
Originally posted by Dan Hughes
Are you getting all the parts separatley then? And can i ask you Matt if i should get 2 upper sway bar sets when i start the outdoor season this year? I have the rayspeed ones but what is the difference between the rayspeed and the yokomo upper one?
Iv seen it on the front of cars, do you think i should get 2 or not?
Originally posted by Matt Howard
You might need to change your setup to give you more offpower steering since thats what the spool lacks. Checkout my spool setups on www.yokomo.tk to compare them to what you're running already.
hi
i was talking about how you mount the steering servo,i have the sd ssg special the one with the silver carbon fiber, some people mount it perpendicular to the wy the chassis goes.
All it is you can get rid of slop in the steering and it is slightly more direct.
Hey, if any of you on the thread are interested in a CGM Conversion kit, check out my posting in the signature portion. Thanks.
does anyone have pictures of Masami's SDW from the recent World's Championship? or any pictures other than the ones found on Yokomo's web site.
any help would be greatly appreciated.
Thanks!
Thanks!
Anyone have tried the new Rayspeed shock towers RS-30 & RS-31?
And is any of you already experience the T6 motors too?
Pops, Matt or anybody that knows,
Ive been informed recently that the sd has a king pin problem, (king pin poping out) , has yokomo resolved this issue yet? If not what fixes are currently available?
Johnny
Johnny
Johnny
Johnny
Be sure to check them before each run.
Originally posted by Blakesrc
Dan,
I just picked up a worlds car and also have a rayspeed swaybar kit, the swaybars look identical to me.
Blake
Dan,
Blake
- JB
Originally posted by pops
It can be a problem, but I think the best fix is the lightweight king pins. These king pins will go straight into the hubs better, which also keeps them from backing off. You can also use a little lock tight if you want. Best thing is not to over tighten the pins, no matter which ones you use, as it can be easy to strip the threads in the steering hubs.
- JB
