Yokomo MR-4TC SD
Quick question.
What is better for indoor carpet racing? SSG or the CGM?
Thanx
Mike
Thanx
Mike
CGM
HTH
Stephen <><
HTH
Stephen <><
Reasons?
mediun to large track
carpet high bite(new) ozite
Thanx for your help
Mike
Thanx for your help
Mike
Considering going MOD motor and was curious what gear ratios you guys would run for a 11X1 D5 I have a 72 or 73 spur and every range of Pinion just trying something new, I got bumped up to Expert in the local club level (which is more like intermediate everywhere else) and everyone is running MODs and I can;t even keep up with a 19T, bummer for me as I love racign Stock and no one in Expert class wants to run Stock. So there is my delema.
Thanks in advance for your responces,
Stephen <><
Stephen <><
CGM no tweek, and very agressive.
Heavy but you can work it down with Ti stuff and tiny electronics.
I went Tiny and love it.
What I use in my Rayspeed SD is
Futaba Low Profile Digital Servo S9550
GM Racing SX12 (smaller and lighter than the QC2)
KO 302f Reciever
That is as light of Electronics as I think is humanly possible without taking everything out of its cases.
HTH
Stephen <><
ALSO JAYBEE What is the part number for the 4degree hub carriers?
KO 302f Reciever
HTH
Stephen <><
Originally posted by Keeebler28
Reasons?
Thanx for your help
Mike
Reasons?
Thanx for your help
Mike
Stephen <><
Stephen <><
Thanks Matt
Your always a great help.
Hey do you have the part number for the 4degree hub carriers, as I am trying to reduse the amount of push and increase my steering.
Thanks,
Stephen <><
Thanks,
Stephen <><
the 4 deg castor blocks are the only ones available, SD-4134
should I use the upper or lower mount postion?
Thanks,
Stephen <><
Thanks,
Stephen <><
9 times out of 10 I run the hingepin for the castor block in the lower hole and space the steering block in the down position.
For more steering should I move the front and rear arms foward or back?
Thanks,
Stephen <><
Thanks,
Stephen <><
hey matt ,
Here is a question for u im running 19t and can almost not let off throttle on my car seems i need a little more rear traction i dont want to change front end which is working perfect what can i change in rear end to get my rear more planted . im running 3-0
block camber link iis 2nd from furtherst hole. tires are magentas in rear cyans in front. any help would be great. and when i mean more traction i just mean when i get omn it i can break the rear end of the car loose ( so need to be more planted in rear).
thanks buddy.
thanks buddy.
Thanks,
Stephen <><
Thanks,
Stephen <><
Originally posted by bigragu
hey matt ,
thanks buddy.
hey matt ,
thanks buddy.
