Yokomo MR-4TC SD
Re: Carpet set up
Originally posted by Local racer
I saw a guy running the cgm on carpet when I asked why he said that this car was desighned for this specific racing ,if this is true I guess I should switch from my black sd and not worry about the worlds car,is this correct
Originally posted by Dan Hughes
Do yokomo do the ball cups that arnt really cups more like hoops as a set. They look a tighter fit than the standard ball cups. And for the rollbars are the blue collars avaliable and aluminium shock mounting balls.
Not in a hurry to find them yet. Do you know what i mean by the roll bar collars? They look like they stop the bar moving left and right.
Its not on any of the Yokomo parts lists. The newest one iv found is the one with the drift parts in it.
dan the collars come with the rayspeed swaybar set but if you have a hard time finding the collars separately you can just use
collars used for the throttle linkage used on gas cars.
cheers. I dont know why i didnt think of that.
The eylet type of ball cup (2each) comes in part#ZC-207A Ball Cups (For Anti-roll Bar) $1.00
what's the difference between 0 trailing steering knuckles and 1 degree knuckles?
I just realised i have both, might want to rip 'em out of the package to try.
the 1 trailing steering knuckles have the axles slightly moved back from the steering pivot point. and the 0 is perfectly in the middle. the zero should react quicker but the 1 trailing should have more on power steering. its almost like changing the caster
i see. Ok I'll think of how both will help me.
just try them both back to back and see which one you like better, it only takes a minute to switch them.
does anyone know what degree of caster the front hub carrier has on the stock SD? just looking through my parts and realized i have some 4 degree graphite ones. also, just got the RS new geo. frt. shock tower and on the package it says (FOR SSS-SIZE), does this mean i can't use the longer SS shocks? and the tower comes with hex nuts & rubber grommets, what are the grommets for?
something i thought was a bit weird is why does Yokomo package the frt. steering block w/ the rear hub carrier instead of with the frt. hub carrier (#SD-4134G)?
- jaybee
- jaybee
i think there is only 4 deg C-hubs available.
Pretty sure the stock ones are 4 deg.
