Yokomo MR-4TC SD
Err, if you're having that problem, maybe you should consider using the grub screws that are supposed to go in the rear hinge pin holder
I'm using the aluminum one's now... I actually only had that happen once.... I've got a set of aluminum front holders coming now.... Well, Rear front and front rear... You get it.... I like being able to use loctite....
Yok CGM
I have a CGM and I need a place to buy spares and upgrades online. My LHS doesn't carry parts for YOK's. Who has the best selection and prices? Thanks in advance, 'blade
Speedtechrc, rc-mushroom, precisionrc..... There's a few more.....
What front/rear springs are you guys running with the CGM on carpet???? Curious if I'm close or way off from the rest.... I had a good setup, needed a little more steering.... Trying to knock a second off my laps... Easier said than done....
whatt about a ssg with cs22s on carpet? im using yokomo flureccant yellow up front and white on the rear?
does it sound bout right to you?
A Gower
A Gower
A Gower
A Gower
Matt, that's exactly what I' switched too... Thanks....
I regularly run Pink in front and yellow in rear with Sorex 28 on carpet. When the grip is on the very high side, i use pinks in rear too.
Matt, I'm running mod w/foams this weekend. I'm going to try to beat the Schumacher squad. Wish me luck!!!
btw: The cgm chassis does twist and its not my tweak board.
Sounds like stlnlst needs to take out that sister kissing 19t. motor in his car and mount up some foams this weekend.lol
Re: Yok CGM
Re: Re: I've just printed out a gear ratio chart...
Originally posted by Matt Howard
IMO as long as you get the same ratio the car should run the same. The advantage of using a bigger spur though is that you can have the motor further to the outside helping balance the car out better, the battery side is heavier if you're using GP3300's.
Originally posted by Cobra81li200
I know why, you got me confused, as you answered the question by saying you tried to use the upper hole...
Anyway, I leave what I posted earlier, it might be helpful for smoe people...
hi... just to clarify, im using the CGM and the manual says to use the upper hole of the front C-hub and the lower hole of the rear uprights... or did i get it wrong?
anyway, i tried using both upper holes on the front and rear, but i have difficulty getting the droop i want with the proper ride height.
any comments would be gladly appreciated. thanks - jason
Matt/Cobra: Thanks!
