Yokomo MR-4TC SD >
Yokomo MR-4TC SD
Like Tree12Likes
Yokomo MR-4TC SD
Old 09-23-2004, 09:05 PM
  #9766
Matt Howard's Avatar
I finally got internet in my room so I'll be able to visit this thread more than once a week. Yokomo has a new body coming out, the status type E. It's supposed to bridge the handling gap between the stratus 2.0 and the mazda 6, more aggressive than the 2.0 but more stable than the mazda. There's another body coming out but I don't remember the details on that one, sorry.
Matt Howard is offline
Old 09-23-2004, 10:15 PM
  #9767
rc_bam226's Avatar
Hey Matt, how's life out there in S. Korea?
rc_bam226 is offline
Old 09-23-2004, 10:28 PM
  #9768
not bad, doesn't look like I'll be doing any racing till I get in the states though. Just way too many obstacles with me traveling to track with all my gear.
  #9769
danjoy25's Avatar
Trader Rating: 38 (100%+)
Default Spool setup
I currently running a front one way diff and would like to try a front spool. What changes would I need to make to getting the initial and mid turn right?
danjoy25 is offline
Old 09-23-2004, 10:46 PM
  #9770
Default Re: Spool setup
try spacing your front arms to the rear and standing your front shocks more upright, both will give you more initial steering. It may take awhile to get used to a spool since it handles so differently but it should be faster than a diff up front and on some tracks it will be faster than a oneway.
Old 09-23-2004, 11:08 PM
  #9771
danjoy25's Avatar
Default Re: Re: Spool setup
I have done the spacing for the front arms and same for the rears as well. I will try standing the shocks. If any chance I am still understeering initially what else can I do.
danjoy25 is offline
Old 09-24-2004, 12:31 AM
  #9772
asw7576's Avatar
http://www.rctech.net/forum/attachme...postid=1108140
cool car, cool mod, and cool pix quality !!!
how did you twist the servo 90 degree ? do you need to drill a hole to chassis ? isn't that hard to drill graphite chassis ?
I'm thinking the same too now
asw7576 is offline
Old 09-24-2004, 04:51 AM
  #9773
Just wondering if.....
anyone has any ideas for receiver mounting.
I have a JrXs3 receiver for my CGM and I have a Nosram esc both of which will fit the area where the radio gear is supposed to go (admittedly with the receiver on it's side) BUT......
to be able to access the pots for adjusting the frequency, even with this small esc, I'll still have to mount the receiver in such a way that I can lift it out to change the frequency as the esc is just big enough to block the adjusters.
I could put it on the servo but I'd rather not and velcro just isn't up to the job and double sided tape would just be a pain replacing every time.
So just wondering if anyone has alternate methods of fixing their receivers in the tray?
Mabuchi540 is offline
Old 09-24-2004, 05:08 AM
  #9774
Default Re: Re: Re: Spool setup
try putting a 1mm spacer under the outside ballstud in the front
Old 09-24-2004, 05:13 AM
  #9775
vtl1180ny's Avatar
My reciever is mounted on top of the steering servo...
vtl1180ny is offline
Old 09-24-2004, 06:34 AM
  #9776
Tommy Bergfeldt's Avatar
Default Re: Just wondering if.....
I have been using velcro for years and it holds up as much as tape. The reciever has been ripped apart about 3 times btw so if it don't hold up well call me something other then my real name.. Another good thing about velcro is that the reciever or ESC does have a bit "flex", more flex=Less vibration-damage
About your placement, Mount the reciever ontop of the servo r buy a Futaba S9550, you get about 1 cm more space for your electronics
Tommy Bergfeldt is offline
Old 09-24-2004, 10:02 PM
  #9777
rjg
Default spring rates
does anyone know what the yokomo spring rates are for each color
rjg is offline
Old 09-24-2004, 10:05 PM
  #9778
Registered User
ritchie's Avatar
yokomo
orange 18.87
green 16.06
pink 14.93
yellow 14.71
white 12.92
blue12.12
rayspeed
gray 19.90
red 18.26
white 17.17
yellow 14.87
blue 14.29
green 13.20
ritchie is offline
Old 09-24-2004, 10:09 PM
  #9779
DickemDown's Avatar
Wink ok my turn
Yokomo
Spring Rating [lb/in]
Orange 18.87
Green 16.06
Pink 14.93
Yellow 14.71
White 12.94
Blue 12.12
Rayspeed
Gray 19.90
Red 18.26
White 17.17
Yellow 14.87
Blue 14.29
Green 13.20
Associated
White 40.00
Yellow 31.91
Purple 30.30
DickemDown is offline
Old 09-24-2004, 10:16 PM
  #9780
Registered User
ritchie's Avatar
i see we have the same charts.
ritchie is offline
