Yokomo MR-4TC SD >
Yokomo MR-4TC SD
Like Tree12Likes
Yokomo MR-4TC SD
Old 08-11-2004, 03:34 AM
  #9331
If you have spare time and wanna know how to set-up your car you should download this file.
http://www.hudy.net/flash_stuff/all_...et-up_book.zip
dicort is offline
Old 08-11-2004, 07:33 AM
  #9332
Sleighty's Avatar
Hey,
Thanks man, ive been trying to get a guide for setup off the internet for a while now.
Sleighty is offline
Old 08-11-2004, 07:52 AM
  #9333
Originally posted by Lonestar
Hey Schrub
1- No you don't. There's a weird angle at which you can remove the bones from the outdrive without removing that damn ring (thank God). However you need to undo a camber link to be able to reach that angle. Another easy way is to open the tranny case and move the diff out, you can also reach the angle that way.
2- Depends.... CGM or SSG?
3- try http://www.yokomo.tk it's maintained by one of this thead's posters... forgot his handle
4- I run a similar setup, stock outdrives or one way and Ti bones up front, and stock outdrives tobee Al bones rear... no problem for the past year. Just don't use Al bones up front, it's too light a metal... I think I read that Delrin outdrives are not considerably lighter... they're just highly expensive
Later
Paul
Thanks for the help! It is a CGM (rolling weight?). Steve...
Shrub is offline
Old 08-11-2004, 09:16 AM
  #9334
Lonestar's Avatar
Trader Rating: 14 (100%+)
I think the CGM weighs a hefty 1600gms on the scale when rtr... it's a sensitive topic
later
Paul
Lonestar is offline
Old 08-11-2004, 09:18 AM
  #9335
Lonestar's Avatar
bone angle for removal... now that I think about it, i'm not so sure you just have to pop a camber ballcup... you might actually have to open the diff case anyway... which is easy as 1-2-3 on the SD don't touch these stupid rings anyway.
Later
Paul
Lonestar is offline
Old 08-11-2004, 09:25 AM
  #9336
vtl1180ny's Avatar
Am I the only one who breaks diff screws???
vtl1180ny is offline
Old 08-11-2004, 09:37 AM
  #9337
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
Originally posted by DOMOisCOOL
Jaybee:
When you lay down the gauge, it reads the ride height. When it's standing up, its droop measurement.
AARGGHH!- I KNEW IT, I KNEW IT. I HAD IT FREAKING BACKWARDS; NO WONDER I HAD NO UP TRAVEL. THANKS DOMO, YOU ARE COOL -
- JaYbEe
JayBee is offline
Old 08-11-2004, 09:54 AM
  #9338
JayBee's Avatar
Post
OK, my next stoopid question is, do you stick the droop gauge underneath the part of the arm where the pin goes through the carriers or the very outermost edge where it juts out ? I've got the SSG
- jAyBeE
JayBee is offline
Old 08-11-2004, 10:09 AM
  #9339
JayBee's Avatar
Post
What's the internal drive ratio of the SSG? sORRY for the multiple posts, I keep forgeting things to ask
- jAyBeE
JayBee is offline
Old 08-11-2004, 10:17 AM
  #9340
sosidge's Avatar
I measure droop from the bottom of the hub carrier. I think that's the most common way.
2.35:1 is the internal ratio.
sosidge is offline
Old 08-11-2004, 10:35 AM
  #9341
JayBee's Avatar
Post
THANKS SOSIDGE!!
- JayBEe
JayBee is offline
Old 08-11-2004, 10:42 AM
  #9342
Yes! (just kidding) if you are breaking dif screws you are over tightening the diff.
pops is offline
Old 08-11-2004, 11:26 AM
  #9343
JayBee's Avatar
Post
DO YOU MEASURE DROOP WITH THE SHOCKS ON OR OFF THE CAR?
JayBee is offline
Old 08-11-2004, 11:29 AM
  #9344
Tek Nickal's Avatar
Both, I think. It takes a while to get the droop right not using the droop screws.
Tek Nickal is offline
  #9345
Isaac's Avatar
off.... at least I do.
Isaac is offline
