Yokomo MR-4TC SD >
Yokomo MR-4TC SD
Like Tree12Likes
Yokomo MR-4TC SD
Old 06-04-2004, 03:18 PM
  #8431
JimmyMac's Avatar
Or you can try the swaybar open ball ends. They have less slop as well. They are just hard to come by.
JimmyMac is offline
Old 06-04-2004, 04:48 PM
  #8432
Jeff Werner's Avatar
Trader Rating: 30 (100%+)
Thanks Matt for any and all help you give!
Jeff
Jeff Werner is offline
Old 06-06-2004, 02:15 AM
  #8433
Lonestar's Avatar
Trader Rating: 14 (100%+)
Good luck Matt!
ball ends: try schum ball joints with RPM cups. It's supposed to be the best.
I run tamiya ball ends and cups... it's already considerably better than the stock junk.
Later,
Paul
Lonestar is offline
Old 06-06-2004, 03:49 AM
  #8434
Post A couple of quick Yokomo questions....
I've seen conflicting information about the SSG but according to the Yokomo site the kit does come with tyres(as in the parts list doesn't say they are not included)...True or False and if true are they any good/last very long.
Secondly if I ran it in 540 stock does the motor plate allow the motor to move far enough away to fit a 40 tooth pinion when using the kit spur (not that I might actually use it but want to know the amount of movement it has).
Thanks in advance.
Mabuchi540 is offline
Old 06-06-2004, 04:39 AM
  #8435
Running a 40 tooth pinion with a 72 spur fits fine. I go between 36 and 42 in 'stock' .
Trevor is offline
Old 06-06-2004, 04:44 AM
  #8436
Cool thanks (my bad I thought the kit spur was a 70) and the tires, does it come with them as the Yokomo site indicates? Oh and from the official parts list it also appears that a one way front end it not optional (as in included in the kit)?
Old 06-06-2004, 05:05 AM
  #8437
The kit spur might be a 70, not too sure on that. As for the tires, not sure on those either, and for the one-way, it depends on where you are buying the kit from, Oceania is standard with a one-way, and America is standard with a diff. I dont think you will need a diff anyway. The standard setup works really well with a one-way in stock most of the time.
Trevor is offline
Old 06-06-2004, 05:07 AM
  #8438
Registered User
ritchie's Avatar
optional, that means its a "hop up" item. you have to pay extra and order it if your hobby store doesn't stock it. i bought my ssg used so i can't answer your tires question, but i did just get the cgm kit and it came with wheels but not tires (tyres)
ritchie is offline
Old 06-06-2004, 05:13 AM
  #8439
Registered User
ritchie's Avatar
Originally posted by Lonestar
utieh,
I'd think endbell too... check out on overrc, in Cobra's report I think there's some pics about how he did his. A fan works just fine too
Weighted my car yesterday... SD SSG with no central plate, no rollbars, Cyclone TC, Older Airtronics 94157 servo (MG), two servo savers to reduce slop, suzuki spindles, Tobee bones rear and Square Ti Front, Personal transponder, Team Orion B rubbers, Orion Revolution, 3000HV's & 3-color Mazda 6 body (not light) : 1520grms
I guess with a little massaging and some more modern electronics, I'd easily go below 1500gms...
Later,
Paul
ssg, no center plate, jr 4750, no servo saver, wide bumper quatum 2 , tamiya 23t ,3300's, ti screw set, protoform mg body 2 colors, personal trans. premounted yok 138g's, roll bars, 53.4 oz. 53 is legal. not sure what the conversion to grams is.
ritchie is offline
Old 06-06-2004, 05:14 AM
  #8440
Default And hence the confusion....
I downloaded their own parts list from the site (I'm looking at it now) and according to that a dot means standard kit part and a * means optional and if you scroll down the list there is a dot next to the one way unit. Sounds like misleading advertising on their part....Grrrrrrr
Old 06-06-2004, 05:18 AM
  #8441
. Sorry, sounds like you missed what I said.
Trevor is offline
Old 06-06-2004, 05:22 AM
  #8442
It seems so while I was typing my own reply lol.
Old 06-06-2004, 07:54 AM
  #8443
Sleighty's Avatar
Default Re: A couple of quick Yokomo questions....
Thanks in advance.
No tyres are included with the kit and the kit spur gear is a 70T 48dp.
As for one ways, Only japanese kits have the one ways as std. That how i understand it anyway
Sleighty is offline
Old 06-06-2004, 08:19 AM
  #8444
Need that Yok CGM Reedy set up if anyone has it. Thanks.
Originally posted by Matt Howard
Pops wrote it down for us and I never copied it to a setup sheet yet, maybe he can post it or I will later today when I get the time. I know it was pretty heavy with the shock oil and a heavy rear sway bar.
coolrcdad is offline
Old 06-06-2004, 10:34 AM
  #8445
JayBee's Avatar
Trader Rating: 31 (100%+)
Post Re: Re: A couple of quick Yokomo questions....
true, no tires are included in the kit only dish wheels, which is actually a very good set. they have two different compounds that i'm aware of. one's stiff and the other is slightly softer.
and the front one-way is a 'HOP-UP'. it is a good hop-up to have in your arsenal
JayBee is offline
