Yokomo MR-4TC SD >
Yokomo MR-4TC SD
Like Tree12Likes
Yokomo MR-4TC SD
Old 05-20-2004, 09:45 PM
  #8341
DOMOisCOOL's Avatar
Originally posted by jas
Does the Rayspeed conversion has the same body mount locations as the standard SD?
Thanks in advance!
The body mounts are about 1-1.5cm wider than the standard.
DOMOisCOOL is offline
Old 05-21-2004, 12:28 AM
  #8342
johnbull's Avatar
Hi friends. Greetings from Malta.
Rayspeed bodymount holes are different to SSG.Much further apart.
Here's my electrics installation. I have a normal size servo - KO digital, GT7 with external schottky diode and capacitor, XXL receiver and fan, and they all fit.
Regards
Joe from sunny Malta.
johnbull is offline
Old 05-21-2004, 12:32 AM
  #8343
DOMOisCOOL's Avatar
Joe,
Is that a special capacitator on the GT7? How did you mount it?
Also, on the GT7, the wire for the switch is on the lower part of the case. How did you mount it vertically?
Old 05-21-2004, 04:45 AM
  #8344
johnbull's Avatar
DOMO.
The capacitor is the normal GT7 one - just covered with shrink tube.
You can easily redrill the GT7 case to put the switch wherever it's most convenient.
Actually since that photo was taken I have repositioned the GT7 flat, instead of being on it's side, the capacitor upright between the fan and the receiver and the schottky diode on the floor between the GT7 and the fan.
They are positioned this way on my son's TC3 also. see photo attached.
Regards
johnbull is offline
Old 05-21-2004, 11:31 AM
  #8345
DOMOisCOOL's Avatar
Thanks.
But how did you mount the capacitator? Double sided tape? Doesn't really seem sticky enough to last a whole race.
Old 05-21-2004, 02:22 PM
  #8346
How does one prepare the gears in the gear box, for the best efficiency? Dry or a certain lube?
alien too is offline
Old 05-21-2004, 03:10 PM
  #8347
I assembled mine with no lube and broke them in by running the motor at 5v for 2 hours. I've seen others use teflon spray. It's up to you. Also, graphite versions of the gears have just come recently. I've never had a problem with mine so far.
Also, after the gears are broken in, you may want to play with the shims. Just don't go overboard or you might get into some problems.
Headbanger is offline
Old 05-22-2004, 01:10 PM
  #8348
NVisible's Avatar
Originally posted by Aku-Man
Thanks lem2, I'll try the tall one.
NVisible, here's my old pic.
can i ask where you got all that blue stuff?
ie: shock mounts, body posts, axles?
NVisible is offline
Old 05-23-2004, 08:43 AM
  #8349
Registered User
Speedtech, Tower Hobbies, RC Model, Precisionrc, and KT Hobbies.
Aku-Man is offline
Old 05-23-2004, 08:46 AM
  #8350
lem2's Avatar
the stuff are probably from RC Square, and its available at SpeedtechRC. You can view the products at rc-square.com
lem2 is offline
Old 05-23-2004, 08:49 AM
  #8351
Registered User
Square did not make any blue part for SD except newly released shock mount.
I used blue spacer and Tamiya alum. ball nuts for my shock mount.
Aku-Man is offline
Old 05-23-2004, 09:26 AM
  #8352
NVisible's Avatar
thx aku-man
NVisible is offline
Old 05-23-2004, 10:49 AM
  #8353
Tommy Bergfeldt's Avatar
Touring Car Nordics in Staffanstorp, Sweden is coming up. I have searched through the collection to find my SD again and race outdoors for probably the first time on asphalt in elec sedan . I will run CGM because i don't have the time to converse it to SSG again
Now the question: What is the main difference in setting up the car for asphalt from running on Carpet?
It'll be heaps of fun!
BTW. I will run Sorex 36R's on some kind of Sorex insert and Schumacher rims (control tire)
Tommy Bergfeldt is offline
Old 05-23-2004, 08:29 PM
  #8354
lem2's Avatar
i stand corrected. so where did you get the blu alum post?
lem2 is offline
Old 05-23-2004, 09:01 PM
  #8355
Registered User
Tobee Craft.
Aku-Man is offline
