Yokomo MR-4TC SD >
Yokomo MR-4TC SD
Like Tree12Likes
Yokomo MR-4TC SD
Old 10-15-2003, 05:49 PM
  #3811
vtl1180ny's Avatar
WYD, I've got a silly amount of money into it and nowhere to open it up and utilize the HP... I like my VFR better anyway...
So, if I manage to switch to the RS towers, can I use the stock shocks with longer ends??? I'm in no mood to be buying new shocks... I'm not going with the whole RS conversion, if anything I'm getting the fbre-lyte or and other tub conversion when they come out...
vtl1180ny is offline
Old 10-15-2003, 06:56 PM
  #3812
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
From what I read you can use long ball ends if you use the Rayspeed Spring retainers.
As long as you like you R1 that is all that matters.
wyd is offline
Old 10-15-2003, 07:49 PM
  #3813
Registered User
2Tenths's Avatar
I've got a question for Kilruf, or anyone else who has the SS Shocks. Are the shock shafts that come with the SS shocks different (longer) than the the shock shafts that come with the SSS shocks. I was thinking about buying just the SS shock bodies instead of the whole shock kit.
2Tenths is offline
Old 10-15-2003, 07:56 PM
  #3814
mo
mo's Avatar
The shock shafts are the same length. The only difference is the length of the body.
mo is offline
  #3815
They are the same length.
James Nguyen is offline
Old 10-15-2003, 08:48 PM
  #3816
JusBox's Avatar
Ok so what exactly does the RS chassis need shockwise? You can't use the stock SD shocks? What would I need to order to get the proper setup? Also, will the stock SD benefit from the longer shocks and would I need new springs cause i have a bunch of yokomo springs for my SD already.
JusBox is offline
Old 10-15-2003, 10:20 PM
  #3817
JimmyMac's Avatar
All I did was buy the shock bodies from Rainbowten. They are like ¥900 a piece. Then I just used the parts from my SSS shocks to build the SS shocks. Quick... easy.... simple.
JimmyMac is offline
Old 10-16-2003, 04:48 AM
  #3818
Smile
Has anyone seen a pic of adatchi's rayspeed SD on the net?
aztecz is offline
Old 10-16-2003, 05:02 AM
  #3819
wyd
Tech Legend
wyd's Avatar
Just put the long ball ends on your SSS shocks and then use the Rayspeed Spring retainers and your ready to run you RS Conversion. My conversion will be here today and by Saturday or late friday night I will have a rolling chassis setup and then I will post how my RS is setup shock wise. If I can figure out how to post a picture I will will do that.
wyd is offline
  #3820
vtl1180ny's Avatar
Ok... The RS setup reqires the longer shock bodies... With my current setup, my shocks are 62mm long and RS Red and White springs, 5mm ride height and 5mm of droop I've got a huge gap between the spring and collar at full droop... I'm feeling that the gap will be even larger with the longer bodies...
Old 10-16-2003, 06:42 AM
  #3821
wyd
Tech Legend
wyd's Avatar
You will be fine with the just using the long shock ball ends. I used them before on my SG in the rear like that and 64mm length is very easy to get. Since you already have RS springs on your car I imagine you have their spring retainers as well so you shouldn't have any problems acheiving the length you need.
wyd is offline
Old 10-16-2003, 02:16 PM
  #3822
Ordered a rayspeed conversion kit, a black SD and loads of other little bits from speedtechrc and hopefully they shud be here this coming week, i cannot wait! Rick
Rick Draper is offline
Old 10-16-2003, 02:19 PM
  #3823
forty6's Avatar
Yep, Speedtech's service is top notch, good prices too.
forty6 is offline
Old 10-16-2003, 03:08 PM
  #3824
Yup i cannot recommend steve at speedtechrc enough, he kept me intouch with what was happening and when the reyspeed stuff was coming into stock, he has been excellent. Rick
Old 10-16-2003, 04:17 PM
  #3825
Yup I agree guys,Steve at Speedtech is on the ball, very helpful and carries everything you need for an SD.Also for overseas racers like myself,my order arrivesusually within 5 days and I can track it on UPS.
Barger is offline
