Yokomo MR-4TC SD
#2986
Both Cars "ROCK" and Both cars can be set up to perform at the same level....
at least there not a TC-3 or EVOIII j/k
just my 2.437 Yen
-Dave
just my 2.437 Yen
-Dave
As a matter of fact, an SD ruined my hat-trick opportunity of 3TQ's and 3Wins in a row by beating me last time out...giving me a 3/2 ratio Good job Jason E
Just my 2.598 yen
#2987
What's the address for CML?
Thanks,
E
Thanks,
E
#2988
Kaizen, are you using the short ball ends or the long ones?
#2990
Originally posted by pops
He posted that he was using Ray Speed Springs and Ray Speed cups. You use Yoke shock ends with the Ray Speed cups.
with the RS cups use the short shock ends. and on the front C-block...use the upper hinge pin hole position.
#2992
Looking for set up sheets for the following racing:
1) STOCK MOTORS-RUBBER TIRES ON CARPET
2) 19T MOTORS-FOAM TIRES ON CARPET
For the SD of course.
I have had trouble finding anything that was run indoors on carpet. Please email me or post the URLS here for me thanks.
I have a setup i came up wiht but im not 100% happy with it. I get the odd traction roll with what im runing. And i cannot get my oneway to work with the setups i have been using. I actually get understeer when using it.
#2993
Hi! I am using the short shock ends -- still can't get lower than 7mm. I am also using the lower hinge pin position on the front c-block. I can/will try going to the lower and see how that affects handling/height.
I read earlier on this forum that I may need to lenghthen my shocks to 64mm for the RS springs/cups in order to lower my ride height. Is this true? Still wondering if there is another way.
Cheers and thanks for your reply.
#2994
#2995
Thanks, I will give that a try.
#2997
well i had problem with ride hight as well in the rear what helped me solve the problem was Adding 2 1/4 oz by the motor cuz the car is un balanced on that side witch caused the side to even out with the battery IF all else false try this but i would recommend it cuz ive tryed everything
#2998
I tried that rear shock mounting a couple of weeks ago and it didn't suit my driving AT ALL. I really couldn't tell where it was hurting my times but the car just felt like crap.
#2999
How does the RS spring rate compared to Assoc. springs? What equals what?
Thanks,
E
Thanks,
E
