Yokomo MR-4TC SD >
Yokomo MR-4TC SD
Like Tree12Likes
Yokomo MR-4TC SD
Old 06-07-2003, 01:27 AM
  #1801
Im running the David Goss setup with a few little changes, you can find it on Mo's website . The track is really smooth and flowing. Most likely be using a oneway. Traction is pretty good.
James Nguyen is offline
Old 06-07-2003, 01:36 AM
  #1802
VenomRcR's Avatar
Which Goss setup? The 5-11-03?
VenomRcR is offline
Old 06-07-2003, 01:47 AM
  #1803
johnbull's Avatar
Hi guys. greetings from Malta.
RANDMAN.
I have been building and racing real race cars - successful ones too - for over 30 years and have learnt quite a bit about suspension tuning. However I cannot understand the advantage of having a trailing top front link like the SD has. I understand lenghtening it or shortening it to vary camber change angles. I also understand altering it's position to vary roll centre, but since the hub pivots on the kingpins I don't see that moving the outer pivot point of the top link back or forward should make a difference.
However despite being almost 57 years old, I am still learning and stiull have plenty to learn, so if anybody can give a suitable explanation I will be very glad to listen and learn.
Regards
Joe from sunny Malta.
johnbull is offline
Old 06-07-2003, 05:36 AM
  #1804
STLNLST's Avatar
Trader Rating: 32 (100%+)
With the Losi my set up's never changed from speedworld to Ripon so the David Goss set up should be a good starting point. You'll have fun there and definately put a oneway in the car. The track is fast and flows.
STLNLST is offline
Old 06-07-2003, 07:39 AM
  #1805
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Johnbull - I didn't think it would make much of a difference if the camber link was trailing or paralell either, but still had to ask
Has anyone gotten the Yokomo graphite driveshaft yet? I got mine, and it is really thin graphite, with aluminum endcups. I can definately see how it could be snapped by a mod motor, just hoping mine will hold up a little better than that.
Randy Caster is offline
Old 06-07-2003, 04:00 PM
  #1806
JimmyMac's Avatar
I have the graphite shaft as well. Looks thin,, but then again.. graphite is pretty strong. I'll only be running it in Stock Class so I'm not too worried about. The thing I AM worried about is the pin that goes thru the graphite and aluminium ends. One side looks like the pin didn't get pushed all the way thru. Kinda shotty if you ask me. But oh well. No time to send it back. If it breaks I'll try a thinner aluminium or titanium shaft. We'll see tomorrow! It did hold up today though for practice (race rained out.) Oh well. Funny weather we've been having here. Well let me go paint a body.....
JMac
JimmyMac is offline
Old 06-07-2003, 06:06 PM
  #1807
Both of the pins on mine are perfect, you might want to try pusing it through yourself...
Old 06-07-2003, 06:44 PM
  #1808
tony montana's Avatar
Trader Rating: 76 (100%+)
Man I really want one of these cars, does anyone have one that they want to trade?
tony montana is offline
Old 06-07-2003, 07:41 PM
  #1809
Check out the thread about MR-4-TC-SD for sale, guy only wants $250 for a NIB car, if you can swoop it up before me
  #1810
BTW, I'm sure the thread is going to get deleted, so you might want to get his info quick.
Old 06-07-2003, 11:18 PM
  #1811
mo
mo's Avatar
Default New SD Shock Towers
OK guys, I finished my prototypes today. I think they turned out pretty good. They are a little rough buy they were basically made with a dremel and a drill press. There are a couple close up pics on my website. www.mo-net.ws under pictures.
mo is offline
Old 06-07-2003, 11:31 PM
  #1812
They look bulky as heck, should hold up well. When are you going to get them on the track to see how they work?
Old 06-07-2003, 11:53 PM
  #1813
mo
mo's Avatar
I'll be heading out to the track tomorrow at 10am for some testing.
mo is offline
Old 06-08-2003, 05:58 AM
  #1814
Jeff Werner's Avatar
Trader Rating: 30 (100%+)
Those do look great Mo! A track report is well anticipated...lol I know the interest in something like that would be high. I ran the PRP Shock Towers on my XXX-S and really enjoyed the extra positions. Looks great!
Jeff
Jeff Werner is offline
Old 06-08-2003, 06:46 AM
  #1815
Hey Guys.
What will happen if a remove the center stiffener? Has anyone tried it?
Explorer
Explorer is offline
