Yokomo MR-4TC SD
Originally Posted by macgyver1432000
Aries326,
Try to look at www.yokomousa.com , then try click "set-up" subtab. There are set-up sheets used my M.Hirosaka at the Yatabe Arena using his SSG. There are some oether set-ups, too.
I've got those SSG setups saved on my PC. Unfortunately, they only have one basic setup for the Rayspeed chassis. I was hoping to find some more Rayspeed setups for carpet but I guess I'll just use the basic setup and go from there.
well i gave it a try this weekend it was pretty good it could have been alittle faster but i wasnt getting motored
i need more on power steering i have a ton off power steering
i think im going to like this car i just need some set-up time i need more pop out of the corners too
any advise would be welcome
runnig 19t quad mag geared 100-37 rubber tires about 100 to 110 strait pretty
tight
tight
tight
tight
Pops do you or Alex have a good set up for speedworld for either the BD or LCG SD..I am selling all my other TC's(8 or 9.. )and I am just running my Yokomo's now.
Mike,
Go to CML website and try chris graigner setup., Works good for me.
Jochim_18,
What website / link is that?
http://www.cmldistribution.co.uk/tea....php?menu=TEAM
Setups page on CML website. Select the car from the dropdown and click Go.
REAR HUB CARRIER/KNUCKLE
This may have been explained somewhere else in this thread, however I haven't seen it. Is there an obvious identifying mark on the rear hub carrier/knuckle to distinguish between 0 degree, 0.5 degree and 1 degree. I am not talking about the alloy ones but the graphite ones.
I can't see any on the ones I have on hand, so I think they are all 0 degrees. Any help is appreciated.
Thankyou
Calvin.
Thankyou
Calvin.
The 0.5 & 1 deg rear hubs have, of course a 0.5 or 1 mark on them, plus R or L, very easy to see. The 0deg hub has no marking.
REAR HUBS
Thanks POPS and CAVEMAN. I will have to order a set of both, as I only have three sets of 0 degree, in my spares.
Cheers
Calvin.
Cheers
Calvin.
what are the best tricks to rebuilding the diff
If you're running stock you can use only 6 diff balls rather than the full 12. I've been using Ceramic diff balls in my diffs for ages, the same diff balls for over 12 months now. They come in a pack of 6 and are great I think you probably wear the diff rings quicker with Ceramics, but they're cheap anyway
