Yokomo MR-4TC SD
After putting the lightened chassis on my CGM, I feel that the car is more responsive due to its reduced weight. This is a worthy upgrade to look into. You may be able to get a decent priced piece on ebay.
Originally Posted by Tsquare
the old Ray Speed Graphite Shock Towers for Frt and Rear
Originally Posted by v0rtex
If you can find some. They've been out of production for over 12 months, and the ones that are out there people dont sell I have a pair, and they're not for sale
Shock Towers
I was wondering why do we have to use the graphite rear shock tower to the front? What aspects are going to improve to the performance?
Stands the front shocks up more for sharper steering response. As with all these parts, you don't HAVE to use them, but if you like the effect then go for it.
Sharper steering response? So, that's why Masami used the rear shock tower to the front. Now, another question....what are the advantages and disadvantages of having a front one-way diff in your SSG?
One ways increase corner speed at the expense of braking stability.
Ok just dug my Yoke out for use in the outdoor season. The drive train seems to have some tight spots in it. I have checked the diff shimming and thats ok it seems as if the bevel gear and the diff gear is rough but they are new.
Anyone got any ideas?
Need to replace a broken cvd. Saw a rayspeed cvd, are they beefier?
Re-lube
Is it advisable to put grease on the bevel gears, and diff grease on the ball diffs & one-way diffs? I am planning to overhaul my SSG and re-tune. Thanks!!!
SSG Conversion
Can I also convert my SSG to Drift version? What part should I replace aside from the tires? I'm using an Orion 23-turn motor..What's the ideal motor for drifting?
is anyone running the graphite ring and pinion
