Xray NT1
#6226
When you start ripping the spurs it tells you to check the play. i`ve destroyed 3 spurs before i noticed the play, after replacing that it was good.
Otherwise run it for ever.
#6227
Hi Guys,
I am blowing out my remaining stock of all NT1 parts. ( No kits left)
50-60% off retail on all stock.. The more you buy the more you save.
I will be creating a price list and updating our webstore. your interested in a pricelist please PM me this will be the quickest way.
Shipping wil be sent via post and payment will be paypal.
Now is your chance to stock up on all parts at a fraction of retail price.
Thats my beauty!!!!
I used CSO brake disk, serpent brake springs!
I dont know if they work with ferodo pads when the material is used!
#6229
My new engine
My new engine-pipe set....
#6230
#6231
Any opinion is accepted for update the car!!
#6232
your car niko is teza!
the only update i could see is aluminium hexagons in the wheels.
#6233
#6234
nt1 parts interchangable
hi im looking at up grading my on road chassis, can anyone tell me if i was to get say a 2008 nt1 could the upper and lower chassis be replaced with newer model ones, around 2010 / 2011. im on a bit of a budget but would like to get an xray and posibley up date the chassis as money alows. thanks to anyone who can help out.
#6235
You can buy a 2008 nt1 and upgrade the chassis and radio plate to even 2012 specs.
The problem with the 2008 chassis (or any pre-2009 NT1 chassis) is the plastics (arms/hubs) were too soft.
I would try to get at least 2009+ chassis where it should have at least front CVDs and then upgrade the chassis and radio plate to 2012 specs.
#6236
Rear Tire Wear
I have been scratching my head at this one. What are some reasons that i would be tearing through rear tires. Meaning loosing about 2mm per 5 min qualifier. I am geared 16/60 23/55 right now and my setup is about 1-2 degree rear toe and 2-3 degree camber. I am getting the right conical wear from the rear setup but i am tearing through rear tires. Is there something else i should look at or is this just normal for xray. My friend has the new KM and same track, same qualifying time, with almost the same gear ratios, he only gets about 1mm wear. Forgot to mention, normal shores depending on traction i run a 35F/37R or 37F/40R. Any ideas?
#6237
Try going 17T on the clutch for a less explosive take-off.
#6239
Also check what middle side pulley you have on could cause excessive rear tire wear also
