Like Tree18Likes
Xray NT1
Old 09-17-2007, 07:56 PM
  #1966
bvoltz's Avatar
Trader Rating: 44 (100%+)
Originally Posted by GK
Here you go...
When making these grooves I have a pivot ball inside the upright so I don't damage the area where the pivot ball sits. You can do the same with threaded holes in suspension arms, just be extra careful when screwing the pivot balls and nuts back in.
Many thanks for the picture... I'm thinking that Teflon tape mite do the trick also...
What do you think of this idea?
bvoltz is offline
Old 09-17-2007, 08:05 PM
  #1967
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Originally Posted by brianhatesnitro
Oh, and the track is resurfacing again today with a more aggressive sand mixture so I have no idea how we're going to make a 60 minute race at the nationals without some 50 shore tires.
I tried 42f/45r on this day, and just couldn't generate enough grip even though the tire wear was high.. Hopefully the new non-water based sealer will fix this problem.
Sounds like they are going through the same thing that the FT Myers track went through. From talking to people that have tried sealers before, the NON-Water sealer....is this an oil based sealer? The FT Myers track has solved the problem with the tire wear and lack of traction too....they dragged regular car tires around the track for an entire day (or more) to remove the sand from the track.... Traction came back and the tire wear went away...now the Fort is realy hooked up!
rcfoolz is offline
  #1968
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
james ygpm!!
Marcos.J is offline
Old 09-18-2007, 02:56 PM
  #1969
Nexus Racing's Avatar
Originally Posted by mtveten
Have you thought about adding them to your store?
Yeah, we'll have to do that .
Nexus Racing is offline
Old 09-18-2007, 02:58 PM
  #1970
CIMRI's Avatar
Sorry about that, I read my notes again and it actually reads the way you would expect.
56.9mm RF
57.6mm RR
56.1mm LF
55.8mm LR
It's odd for sure, my car should be perfectly balanced. I use the Xray balancing posts and then allow the low side to sit on a scale to measure the exact weight. Right and left are within 1 gram on the rear, and 2 grams on the front.
I then used the Xray tweak station to ensure everything was completely square there as well.
My setup was not quite ideal this weekend. Interestingly there were two left hand corners giving me a hard time where I felt like I needed more turn-in and usually ended up washing the front a bit which would have increased my RF tire wear. Toward the end of the race this eventually caused a slight spin as the tiny LR tire because the droop setting changed by so much.
Hi Brian ,
I have the same wear (very close) exsp. the left side of the car wear a lot because of the high speed left corners.
This is what I do for 1 hour mains.
BEFORE AFTER
LF 61 mm (40s) - 56 mm
RF 60 mm (38s) - 56.5 mm
LR 63 mm (42s) - 55.8 mm
RR 62 mm (40s) - 56.2 mm
CIMRI is offline
Old 09-18-2007, 03:22 PM
  #1971
rmdhawaii's Avatar
Originally Posted by CIMRI
Hi Brian ,
BEFORE AFTER
Are you running the 25T or 26T side pulley? Also, how does the car drive throughout the race?
rmdhawaii is offline
Old 09-18-2007, 07:01 PM
  #1972
Hi Brian ,
BEFORE AFTER
I'll have to try that in practice next time out with harder shores cause i could never get a 38 to last an hour on this surface
brianhatesnitro is offline
Old 09-19-2007, 07:46 AM
  #1973
CIMRI's Avatar
Im driving 25 side pulley. the car handels well w.o problem . this tire choice is good for mid-high traction tarcks. I did this setup in my last 3 race (1hour main) and had never problem. because of the high rear and left tire wear after 10-15 min you have a very good over drive and a car balance.
For shorter mains is my advise : 0.5mm left/right split and 1 mm front/rear split .
CIMRI is offline
Old 09-20-2007, 12:22 PM
  #1974
DS Motorsport's Avatar
Hi there, i just bought a nt1.
It's the car which jilles drove the winternats with.
I'm very happy with, it has a lot of options and spare and the car was a bargin.
But there wasn't a manual and other documentation included.
So i wanted to order it but i can't find the part numbers for them.
Does someone knows them?.
Thank you.
DS Motorsport is offline
Old 09-20-2007, 01:21 PM
  #1975
teamgp's Avatar
Thank you.
You can get them online for free here on the XRAY forum.
teamgp is offline
Old 09-20-2007, 02:10 PM
  #1976
RC America's Avatar
Originally Posted by bvoltz
Where can I get them?
Xray sales the same nut in silver. (960240)
Ralph Burch
RC America is offline
Old 09-20-2007, 02:54 PM
  #1977
yes i know that they are online, but these aren't printable, and i would like to have the original manuals instead of one's printed bij myself.
i think xray don't sell them apart from the kits.
Old 09-22-2007, 10:17 AM
  #1978
rmdhawaii's Avatar
What bearing oil are you guys using? Considering that the instructions expect you to oil the bearings before installing them, I'm surprised that it is not included with the kit.
Anybody just decide to swap out the bearings with another brand? If so, why?
Old 09-22-2007, 11:54 AM
  #1979
GK
Suspended
Bearings in the kit are pre-oiled, no need to do anything with them. For maintenance I use mobil 1 synthetic oil...
GK is offline
Old 09-22-2007, 12:33 PM
  #1980
i use serpent premium lube or serpent bearing lube, works great. Premium lube i also use it for the driveshafts and in qualifing i put a drop on each pulley to get a bit more roll in the car.
Today i drove my nt1 for the first time.
It handles very different then the 720. Feels much smoother and the car handled like it was on rails.
Wasn't faster yet then with the 720, was still .2 seconds off.
But i only did 60 laps today.
Tomorrow i will race it for the first time, so then the track will be much better and the car is still really understeering which is easy to fix.
