Engine tuning tips
Engine tuning tips
OK I have been playing with my engine (CX12 slide JP Black) and found the following things:
- Starts and idles fine.
- It idles nicely.
- When you give it throttle it accelerates nicely with a nice plume of smoke (a fair bit actually)
- If you accelerate lightly or in a short burst it will return to normal revs quite quickly.
- If you accelerate for the length of the straight it will run-on with quite high revs for a period (5-10) seconds then drop back down to normal revs. I am used to engines revving high then low but the drop off on this engine is quite significant.
I am thinking that the low end is too rich meaning that I am having to use a high idle to keep it going. When I "clear its throat" it will idle high till it loads up and drops the idle again. The idle slide is open mayby 1-2mm which seems like alot.
I am running about 3 turns on high end needle and 3 1/2 turns in from flush on low end (black) needle. Mid range is flush.
Any ideas????
- It idles nicely.
Any ideas????
Re: Engine tuning tips
- It idles nicely.
Any ideas????
- It idles nicely.
Any ideas????
I run 15% nitro, 9% caster and 3% Neo synthetic.
Yes I agree. I have sealed the engine. When I make the opening down to .5mm it stalls. So therefore I assume the low end is too lean......
Sorry about all the questions but I bought this engine 2nd hand and I have no instructions with it. So I am trying to get some baseline needle settings.
It doesn't mean it's too lean when you have the idle stop at .5mm and it stalls. I run all mine at that or less. When it stalls, is it choking? Could be the low end is too rich.
The fact that it'll run at a high rpm after a run then drops significantly when it idles tells me the bottom is too rich.
Air leaks usually gives you inconsistent idle.
sorry guys I meant rich
No problem.
OK new tuning question.......
I have leaned out the low end needle a bit, mayby 1/3 a turn. Weather is a fair bit different today as well. Now after a long burst of throttle the engine returns to a fairly low idle right away then 10-20 seconds later the idle INCREASES. I am thinking that the low end now has gone too lean. Also the performance off the line seems flat. When I clamp the fuel tubing the idle of the engine increases almost immediately.
Man the low end on this thing is touchy.
Yes you went too far. When I adjust the needles, I go no more than an hour at a time and see what the engine is doing. I don't turn it 1/3 of a full turn.
When I say an hour, think of the needle as the face of a clock. 1 'o clock from 12 o'clock is an hour. 2 o'clock from 1 o'clock is also an hour and so on.
In your case, turning it 1/3 of a full turn you went from say 12 o'clock to over 4 o' clock in one fell swoop.
