Team Corally RDX Phi
#1339
Mine actually came with 1.3mm hole pistons.... But mine was from a batch or two ago. The very latest batch might come with 1.1s, but I can't confirm that :P. Either way, I think both pistons are good. The 1.3's seem to give a little more steering as it transfers weight around a lot more, but 1.1's pack up and make the car corner flatter, and smoother.
-Korey
-Korey
#1341
Thats because the car is so popular!!!! hahaha You can try
http://www.stormerhobbies.com
Bob usually has a good selection of parts in stock
-Korey
-Korey
#1344
#1345
Just stick your calipers in one of the holes and measure the lil' sucker.
#1346
Help! Major Brain fart
I'm almost finished building my new PHI and started to mount the shocks. Looking at the directions they are supposed to snap onto studs (balls) that I mount but my shocks already have ball mounts in the cups and there are no threads for my to use to screw them to the bulkheads. My brain has shut down and I can't figure out what I'm suppose to do. Would someone take pity on this FNG and set me straight!
#1347
#1348
Shocks
Thanks Stilskin, I thought I was loosing my mind!
#1350
Now, if we only had Team Tamale braces already modified for the Phi shock towers.
I modified a set of them from my RDX to fit my Phi...and presto! The standard RDX braces work on the front end tower; but, you have to cut out a corner of the RDX to allow for fitment on the Phi's rear tower.
Kewl add-on...
http://www.teamtamale.com
Kewl add-on...
