Team Corally RDX Phi
#692
set up
I was looking at the set up sheets on the corally usa site and was wondering what 3h tam means for pistons and under down stops 5 ae mean.
#693
I used 3 hole tamiya pistons, instead of corally pistons. AE makes a droop guage, which we used to set are droop to the #5 setting. If you have anymore questions , let me know.
#696
Phi bearings
Per the assembly manual, the new Corally RDX Phi ("US") has:
4 ea. 1/4" x 3/8" (for diffs)
2 ea. M4 x 7 x 2.5F - flanged (for belt guide)
6 ea. M5 x 8 x 2.5 (2 ea for diff/spur/steering)
8 ea. M5 x 9 (for axles)
4 ea. M10 x 15 (for bulkheads)
Therefore, the "US" car kit with the diff/diff has a total of 24 bearings.
For the "EU" car kit with a one-way, delete 2 each of the 1/4 x 3/8
and 1 each of the M5 x 8 x 2.5 (21 bearings + those in the one-way).
FYI...I provided this list to Acer Bearings and anyone can order ceramic bearings in a package set for either Phi from them.
#698
#699
Remember...To have fun this coming weekend. And make us proud.
#700
don't forget me
#701
Hi All
is 2 x 1.3mm holes with 40wt oil the same as using 2 x 1.1mm holes with 30wt oil ?
Thanks Ya`All
Thanks Ya`All
#702
#703
What I've seen alot of peeps (SoCal version of mate) do is shave/file a little bit off the ends of the topdeck so it doesn't acctually touch the ends to the bulkheads. It should fall right in place with no pressure... it does help keep 'er flat after a wreak
#704
Location: Bending Corners R/C Raceway(s) 2190 North Canal Street Orange, CA 92865
Official Trophy Race Name
"The Summer Slam"
presented by
Bending Corners Raceway(s)
Flyers are being completed and will be distributed this week are you on the mailing list?
see track photos at http://bcraceways.smugmug.com
Mark your calendar for Saturday, August 18th for "The Summer Slam"
"The Summer Slam"
presented by
#705
