Team Corally RDX Phi
#3061
Jeff
#3062
Built a scale system and weighed my PHI. Here is what I found. Car without the body weighed 3lbs. 2.10oz total. Left Front 333 grams, Right Front 387 grams, Left Rear 348 grams, and Right Rear 354 grams. The car with the body weighted 3lbs 6.3 oz. Should make any changes for outdoor asphalt racing?
#3064
Looking at the cars side by side and looking at the part numbers in the manuals, the key items I discussed earlier are different. You would need a new chassis, top deck, suspension blocks, diffs, bulk heads, shock towers, and such. The suspension and roll center blocks are really the only things that transfer over. Maybe the bumber and mounts......
#3066
The price of converting would be cheaper than a kit, but not significant enough to out weigh the knowledge you'll be building a new car with all new parts. Thats my feeling on converting compared to buying a new kit.
#3067
thanks alot for all this help!!!!
#3068
cool thanks man.i'll down load a manual and see what i need.i didnt know how much they changed.or if any of parts were the same.this is my first corally car,ive ran losi,ae,and yokomos befor.thought id try this car out.will convertting benfit my car alot or should i just race it the way it is.
I love this car and I've definately gotten faster and more consistant with it.
Mike
#3070
hey guys
any word when the phi 2 will be available in the states???
#3071
hey guys,
im running stock with the delrin spool and im break drive shaft protector clips nearly every run sometimes 2 a run, now its not the car its me, im nt the best driver but is there any way i can reduce the amount of blades i use up?
also i bought the 08 diff so i have the old diff there, if i put a pulley on this and glue cardboard to the diff rings can i use this as a slipping spool? just for a bit of give?
also bent a kit (aluminium?) drive shaft are the steel ones any stronger and at what weight?
finally with the front hubs i broke 2 this weekend (bad weekend) and know there is aluminiums hubs, if i run the aluminium whats next inline to break? arms or hingepins? how strong are these? which aluminium hubs are the best?
cheers guys car handles great just trying to get it to stand up to my abuse a bit more as i learn to drive
#3072
#3073
hey guys,
No major way to reduce that. Typically the blades are changed every other run for heavy racing. If you want to really reduce it, consider the steel blades and modified bones by Specialized RC that we make.
Jeff
#3075
CorallyUSA (Florida)
Superior Hobbies (shares space with CorallyUSA)
Ampdraw Hobbies (San Diego, CA)
Stormer Hobbies (out your way)
I assume that you mean for Phi cars; but, all should carry pretty much everything...
Bill
