Team Corally RDX Phi
#1741
I havent really had any problems with the bump steer. I honestly have really even noticed it. It's nothing like the old car, but I'm running foam tires, so the geometry is a little different and the suspension won't travel as much to actually SEE the bump steer.
Which way is it bumping? I'm not sure any of the other guys are really messing with bump steer. Maybe Jeff can hop on here and give some insight on this.
-Korey
-Korey
The new car bumps the toe inward as the car front suspension compresses. Bitter and Toso warned me of it. I called Toso and asked him and he said shim it on the steering below top deck, but didn't know the distance. He said on his car it was dropped quite a bit, actually near the belt, but didn't know the exact mm in length. I tried a couple, but if I knew the exact length it would save me a lot of trial and error.
#1742
Hmm, maybe I'm going in the wrong direction. Thanks for the tips.
#1743
I think where you shim it depends on which direction it is bumping. The old car had a lot of bump out, and I think what brian suggested should fix that on the old car. What Toso is saying should help on the newer car as you are trying to reduce the amount of bump in, and effectively doing the opposite of what we used to do on the old car.
-Korey
-Korey
#1744
ive been having problems with breaking front arms.i have 35s on now,are there any softer ones?
#1746
Since we switched to the 5 arms, we havent had an arm breakage problem.
#1747
#1748
part # for the 5s? are the rears recomended or not necessary
#1749
#1750
They make 5s but not sure if that will solve your breaking issues. The difference from 35 to 5 should be minimum. Are you using the plastic lower bumper and thicker bumper. Helps to protect the arms. Also not running the aluminum knuckles will help but you will end up with more broken knuckles.
#1751
The #5 arms are more than a little better than the #35 arms. They are a significant step against breakage on both carpet and asphalt.
The stock Phi bumper is nicely shaped but not hard enough to stop itself from hitting the front suspension in a heavy front/side impact. Get the Specialized hard foam bumper and the lower plastic bumper combo.
Incorporated with the above, aluminum knuckles rule.
#1752
-Korey
#1753
i have found that runningthe alloy steering knuckles a bonus. I have also fitted steel driveshafts to the front of the car...
would rather break a wishbone as its easier to replace quickly.
i run a spool so thats tends to be harsh on drive shafts as well.
#1754
Very true and I run them on carpet, but not a big fan of them on asphalt. Bitter and I tested them side by side with plastic and they do take away a hair of steering. Although very subtle. I run the car on asphalt with sloping candy cane curbs so breaks are much less since you roll over the corners instead of grabbing the tire toward the barrier. I guess it is just a matter of tradeoff. Also on asphalt i run a spool with metal blades with steel bones in the front, aluminum in back so the steel holds up better too.
#1755
-Korey
-Korey
