Mugen MSR777T Conversion Truck Kit
The bulkheads will fit but you'll need to get MP777 parts like; radio tray, servo saver, steering plate, front and rear lower suspension plates and hinge pin holders, front plate, front upper arms, hub carriers, front shock tower, roll center inserts and radio plate posts.
Have fun.
Have fun.
Yes it will work but you don't need half the stuff arecee said you need. I used a k3 with the MSR kit and all you need is the steering system i.e. the top plate and steering assembly. I have a slightly used msr conversion for sale also.
You are correct that you do not need the narrower hinge pin holders and can get by with the old, wider 7.5 ones. However, the parts list I gave him would bring his conversion up to the 777 spec.
The msr conversion comes with the radio tray. And yes, I know you need the narrower top plate.
