Getting High End Servo, Need help
Hey I have a tc3, and I'm looking in the market to buy a servo. I have my eyes on the 2143 and Airtronics 357. Should I get digital or analog?
What are some other good TC servo's?
Stay digital, but you can't go wrong with either. I run the 2143 now for a couple years and love it!!!!
Kevin
Kevin
Take a look at the Multiplex Profi Speed v2. They're strong as hell, reasonably fast and you can buy one for around 50-60 bucks new.
Regional Moderator
Digital is the way to go.
evoracer - those prices you mentioned, is that for a digital servo?
Hey, thanx for the information. I was wondering why digital? I heard that they don't recenter right. For the Ko I just saw that it was FET, what does that do? Also if I wanted the top of the line airtronics digital, would that be teh 757?
What is the FET thing?
If you have a Computer Radio, buy the FASTEST servo you can afford. you can always adjust out some of the speed until you get used to it. Once you have driven with a High Speed servo (Digital is more precise) you will NEVER be satisfied with anything less again. Anything MORE than .10 should be considered slow. I use JR & Hitec Digitals with good results.
go analog servos and get them from ko best servo's arround
heap's of people i know have alot of problem's with digital servos and now most people that i know of in australia use analog.
only my opinion
only my opinion
Hey guys I have the airtronics 158 from a buddy thats broken. Should I fix it or invest in another one?
the firgures for the 158 are
130oz
0.09 at 4.8 volts i believe
130oz
From my Friends that haved owned Airtronics servos, it is NOT cheap to have them repaired. Especially the Digital servos.
Both my JR and Hitec servos have 2+ year warranties.
re:
hey man, i know what your hoing threw. i was looking into servo upgrade before christmas, and i was told to get the 2143 kopropo ....so i did. now , man you won't be dissatisfied at all. this servo is da chit...i hope this helps you out on your quest !
I'm using the KO PDS 2123 - real good. Simply the one with the best data I could find but it also one of the most expensive
Digital ones: Smoother / better resolution, better torque regardsless of position and ultra strong holding power.
And a good servo is worth taking to the next car, when you eventually reach that point...
Will the Ko work fine with my m8?
