O.S 12TZ (P) 5-Port Flywheel?
Hi guys,
Can anyone tell me what type of flywheel I will need for a O.S 12TZ 5-Port (from Kyosho) to fit on a Kyosho V one S?
Thanks in return.
Thanks in return.
No, the one that comes with the kit is way too small.
I also ordered part FD49 which is a flywheel specified to fit OS engines, but that part is too small as well.
Can anyone help?
Can anyone help?
Can anyone help?
Can anyone help?
Trader Rating: 9 (91%+)
Hi guys,
Thanks in return.
Thanks in return.
Sorry guys,
The inside diameter of the flywheel, where the crank is supposed to go through is too small.
What is even more stupid, is the fact the V-one-S is a pull start and I chose a pilot shaft engine, which doesn't properly fit my car!
Is my verdict already clear, or does anyone else have a possible solution?
Thanks for the help guys.
Sorry guys,
1. 3 port
2. 5 port
In 3 port they are other 3 differences shaft
1.1 Standard shaft
1.2 Short shaft
1.3 Pilot shaft
In 5 port it is only 1 type of shaft
2.1 Pilot shaft
You can try to change the crankshaft from Pilot to short shaft. The part number is 21532050.
Remember 5 port shaft has a bigger hole (Turbo Crank) vs 3 port.
Regards,
Alright,
thanks for the advice. Great help. I think I might just have to try returning it if possible.
Thanks again.
Thanks again.
Your going to need the long shaft (standard shaft), and the prop washer, AND the FD49.
Thanks to everyone for their replies and advice.
These forums arre great help thanks to you guys.
Regards,
Blazin~
Regards,
Blazin~
These forums are great help thanks to you guys.
Regards,
Blazin~
Regards,
Blazin~
Sorry - double post.
Go on the kyosho website and look up the part number for the V1R, you will need flywheel and clutch assy.
Those 5 port motors go really well too.
