Pinched Nitro Motors???
I had a p5x and a s7II, they both started to get tired so i had them pinched, by a pro, break in using heat cycle method, i had both motors brand new and always ran them about 220 degrees, the problem is now they both wont run right, they will not clear out on straight away unless there running at 280 and up, by then it ruins the glow plug, i have several .21 motors and they all run fine expect the two that i had pinched, any else have this problem?
are they definately fully re-broken in?
i repinched my os vspec and had similar problems, until i reaised that i had given it a bit more pinch back than i first realised. keep running it ever so slightly rich on low end and top end needles, and dont go full-on with the throttle till it starts to free up just a fraction. you'll feel it as it gets run-in.
also my needle settings changed after the repinch, perhaps yours have too. put everything back to factory settings and do the usual from there.
are u running any shims? were you before the pinching was done, when the motors were still good?
Did you replace the rods after break in? If not there may be excessive rod bushing play which will cause you to go through glow plugs quickly.
Try leaning out (turn clockwise) the low speed needle about an 1/8 to a 1/4 turn and see if it helps with the bogging situation. Pinching the cylinder restores lost compression and can make you have to readjust the carb.
simonr23 yea i had another guy at the track tell me they take longer to free up, i have about 4 full tanks of heat cycles, then another couple of tanks on the race track for tuning, oh i did reset the settings to factory settings before the break in, i did add 1 thin shim in both motors for %30 nitro.
Who did it for you? I would not send a P/S anywhere but OSrocket or Ray-A-racing. If it's really tight it is a good idea to preheat the engine with a heat gun to get things going more easily.
There is a local guy at the track that does the pinch, I check his pinching machine out it is the same one that OSrocket or Ray-A-racing use, is it ok to have it pinch that much that you would have to heat it up with a heat gun, i notice some companys offer light,med, and tight pinch, what do you guys order? and the local guy that does the pinching probally has done 70% of the people there, havent really heard any complaints.
Your engines probably need new front bearings. Ask any motor guys they'll say the same thing. They will run hot because they have an air leak into the crankcase. Every 1-2 gallons replace the bearing. I oil them with quality synthetic oil and use inner and outer seals.
Replace the rod first, then possilby bearings. Those pinched motors really need a new rod after they have been broken in most of the time.
