Xray T2 64p
normaly i use 116spur http://www.precisionrc.com/nv/car/home/index.is
and on a pinion any where between 28-31 , check track sizes and rollout , tire
size, you should start with a low pinion and work your way up as tire wear out
good luck
good luck
Xray has now their own 64dp spurs:
305882 Spur Gear 112T/64
305884 Spur Gear 114T/64
305886 Spur Gear 116T/64
305888 Spur Gear 118T/64
http://www.teamxray.com/teamxray/pro...Gear%20118T/64
Originally Posted by MikeXray
The X-shop site sucks I can't find a link to actually order them.
The new 007 comes with a 116t spur which sounds like a good starting point.
Originally Posted by Anthony.L
Funny, I just went to the X-Shop, clicked search, and pasted in the part number. It found the spur and was able to add it to my basket.
that's what I did and I only get the info, no price or add to basket.
xray spurs they are nothing but prc spurs and charge you more for them , go
straight to http://www.precisionrc.com/nv/car/home/index.is
this spurs are goodddddddddddddd as you see they put 64p 116t on the
new t2 007 that should tell you something
can you explain them , are they making their own spurs cause i bought an xray spur gear and matched it up prc spur and they look the same to
me
me
me
me
The following lines of spurs will fit the XRAY 3-hole pattern: XRAY (obviously), PRS, RW Racing, JWerks.
AFAIK, spurs from Robinson Racing, Xenon Racing, Kimbrough, Corally, etc will not fit because of the hole pattern.
I use RW Racing 64P spurs on my XRAY TC. Their machined gears are durable, thin, white in color, and IMO look very trick on a TC.
Originally Posted by Nexus Racing
XRAY spur gears are molded from a composite (material similar to their hard arms), PRS gears are machined from a delrin-type material...very different in that regard.
u will probably need to file just a teeny bit off the CF top plate otherwise the screws holding the spur will touch it..
