CRC's New Generation-X.... Your Thoughts?
#361
Originally Posted by vtl1180ny
Actually it could be much worse, I have the Nomadio in there but no sensors connected... My 3.2 was much worse... I don't know if the Nomadio is going to stay in the car, I'm bringing my 3PK with FM and Spektrum, I've been having radio issues....
#362
Whats the size of the front wheel bearings for the car? I got the front end kit, bearings are a different size that what I had on before.
#364
Thanks.
#365
Does the Gen X kit come with the bearings?
#367
but not with the sensor tranreciver, i now use spektrum in my Ko helios
Shaking servos, will not connec, osv.
Alf
#368
Originally Posted by nnick
You can buy a clone It's cheaper than an original one and you get to have same number on all classes you run
it's built from MRT
thread at rctech http://www.rctech.net/forum/showthread.php?t=117075
Nick
it's built from MRT
Nick
great idea though... and it sounds like a great product..
they really should make it with "ears" though
#369
Originally Posted by omaha_racing
Sp what are people using to spacer the transponder?? I thought that the kit would arrive with the aluminum spacers like they show in the pic. Oh well cant have it all, I guess.
#370
Originally Posted by fraz
The brilliant servo mounting location kind of backfired for me. Most of the tracks around here have a tower for the timing and scoring loop. I lost like 30% of my laps with the transponder mounted down below. I have mine taped to the top of my servo.
#371
My local track (CRC Raceway) has the transponder loop on a "bridge" above the track instead of under the carpet also. All I needed to do was mount the transponder with the label facing up (instead of down) on top of two 1/8" plastic shock spacers, and it counts fine.
If you need to get it even higher, you can mount it on 2 short threaded stand-off posts.
#372
I'm looking at setting up my electronics in the GenX now. Here's a question/request:
The ABP battery braces, especially the first one. I could probably take about 1/8" of the material on the front edge of that to allow more room for electronics.
Anyone see any problem with this?
Is this part even necessary?
I could probably take off a bit more if that second hole wasn't in there (with the batteries mounted forward).
Next, It would be really nice to have a part specifically made for this instead of me having to grind it down...CRC can you make it?
#373
I'm installing some of the electronics in my new GENX... if anyone can share body off/on pics of their setups that would be cool... I'm going to start a new thread for 12th scale pics... I don't think there is one yet
#374
#375
Thanks... that thread is almost a year old... half the pics are missing... and most of the ones that are left are body-off... I set up a thread for both body-on and body-off pics of recent cars... so feel fre to post
and thanks for the link.. there are some setups in there that I can get some ideas from
